Convertible Boots - manual versus power
Old 09-27-2011 | 04:21 AM
BASSr's Avatar
Car: '90 IROC Convertible
Engine: 305 TPI LB9
Axle/Gears: 3.23 Disc Brake LSD
I had an '88 IROC convertible with a power boot. Now I have this '90 IROC convertible, got it about 2 months ago and the center switch on the console was not working (or I thought)
When I checked it out this last weekend, I looked at the boot latching assemblies and did not see and power solenoid assemblies anywhere.
Obviously a bit puzzled as I thought all the ASC conversions (the 6th digit in my VIN is a 3) came with power boots, not manual.
Anyone know what the deal is on these? Were some of the boots manual and some have the power solenoids?
Old 09-27-2011 | 05:56 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Re: Convertible Boots - manual versus power
Not entirely sure what you mean. My 88 has the central switch for releasing the tonneau cover. To open the trunk, I have to manually unlock it with the key at the rear even though it is a 'soft close'
Only on hard tops was there a central switch to open the boot/trunk as far as I'm aware.
Old 09-28-2011 | 04:25 AM
BASSr's Avatar
Engine: 305 TPI LB9
Yes, this is what ASC did when they converted them to convertibles. What is puzzling me is that my '90 does not seem to have the power boot. Not that it just does not work, but I checked and I do not see any solenoids attached to the latching mechanisms.
Any one else have just manual boot on a '90 IROC Convertible?
Old 09-28-2011 | 12:21 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Possibly, a previous owner removed inoperable solenoid assemblies and did not replace them leaving you with no electrical release for the "boot".
Old 09-28-2011 | 06:50 PM
Mooses92's Avatar
Car: 92 RS Convertible
Engine: 305 ( L03 )
My 92 has solenoids that "pop" the tonneau cover up as well. I can't imagine a conversion company expecting us to have to search for two small wire hoops next to a seat every time we wanted the top down. I suspect the previous owner got Cheap and just rigged something. I would bet he showed the vehicle with the top already down and then put it up for the potential buyer. Luckily the release solenoids are available through several people on this board ( private sellers )
Old 12-11-2011 | 01:47 PM
fivestar's Avatar
Car: IROC and 65 Mustang
Engine: IROC V-8
Axle/Gears: posi traction
My 88 Iroc convertible only has a manual release, the button between the power window buttons does nothing when pushed. I have looked for any signs of an electrical release or selenoids but there is no indication of ever having anything but a manual release. I have owned the car nearly seven years and am the third owner (bought it from one of my brothers). I ma going to hit some junk yards to see if I can find and electrical release.
I will say that it is not much trouble to manually release the tonneau or the top... to be honest up until recently I did not even realize that some Irocs had an electrical release. I will look into it though as finding these electrical release units will be harder to find as time goes by...
Old 12-11-2011 | 07:31 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
did you pull the rear side panels off?the solinolds are behind them.i had to bypass a switch on the trunk latch so my switch would work.it was a safety switch that prevented the tournue cover from opening when the trunk was open scratching the paint.
Old 12-12-2011 | 03:16 AM
BASSr's Avatar
Engine: 305 TPI LB9
You have any pictures or further info on the relay on the deck lid hatch pull down and the other relay? Guess those are specific to convertibles since the power has to work with the tonneau cover.
My '90 had the rear deck lid power hatch replaced and the power to the tonneau cover does not get to the solenoids, solenoids are good. I pulled the rear seat panels off and put 12v to each and theu work, also made sure I had 12v to the tonneau cover switch on the console, so it must be the safety switch you are talking about here that is keeping mine from working.
Bruce
Old 12-14-2011 | 11:15 PM
fivestar's Avatar
Engine: IROC V-8
I have taken off the side panels to re-cover them and again to change out the speakers and no solenoids. Just the mechanisms on each side to release the tonneau.
Old 12-17-2011 | 05:51 AM
fivestar's Avatar
Engine: IROC V-8
pic/thumbnail does not come up
1992 Trans Am
05-10-2023 07:19 PM
jhawkeye
05-25-2022 06:33 PM
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
Vintageracer
01-10-2020 05:33 PM
86IROC112
09-07-2015 01:37 PM
Quick Reply: Convertible Boots - manual versus power
