Wow! A 5 speed IROC Vert with 16,900 miles for $2500!
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Looks like its been sitting since 1991 but this seems like a car you could restore and make some $. Looks all original and being as its in N Cal I wouldnt imagine any rust.
http://stockton.craigslist.org/cto/2302278419.html
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Wow! A 5 speed IROC Vert with 16,900 miles for $2500!
Hmmm....
$2500 + $1000 for shipping + new fuel pump/gas tank/injectors/etc. to get it started...
Oh man, why'd you have to post this ad?
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Wow! Nice price! Kinda hard to believe the mileage, though... HHHmmmm... Tracy, Ca isnt that far from me...
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Suspisious. Not running is understandable, but why does a 2-year old car with 16k on it get parked and have the interior disassembled?
Even so, if it's not rusted and it's fairly complete, it's a steal.
Strange, but possible. My dad bought his '67 Firebird convertible around 1983. It only had 56,000 miles as it sat in someone's garage for around a decade. Mice had eaten some of the interior, the top was shot, and so was the paint job. Of course, 56,000 is more mileage than 16,900, but still - if someone doesn't care about the car, then they don't car about the low mileage either. Someone needs to check it out, and if it is legit, let me know so I can buy it!!
Axle/Gears: BW 3.45
Well, apparently it was parked uncovered in a barn in 1991. The owner said it was bad enough where he saved it from the scrap yard in 1999. It's been sitting on the side of his house ever since.
I'd imagine that critters have pretty much chewed up the interior. I asked the owner to send me some more pics.
Axle/Gears: BW 3.45
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
As for this vert, I'd be interested, but would have to verify the mileage and everything... and after all that, if you're rebuilding the car completely anyway, does the mileage really matter? I mean, if you find a car with 100k that was maintained immaculately vs. this car which looks like it was abandoned, which is really better?
Axle/Gears: BW 3.45
Don't I know that feeling... I just got my 91 Formula back on the road... well, sort of, and it is one of those things that you just can't stop working on until it WORKS.
Yeah, in the end it smarter and cheaper to just buy a mint one. But hey - that's not how we roll.
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
Subbed, Just want to see what happens to it hehe
Axle/Gears: BW 3.45
Original owner blew the motor. It's needs are adding up.
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
I wish I could check it out first hand, make sure rpo codes match its legit like he says and has only 16k on it as well as figure out exactly whats not making it run. I would totally buy it and ship it turn that sucker into a show piece!
Axle/Gears: 9-bolt/3.45
Looks like a good deal, regardless of the work involved in bringing it back to life. Most used cars always need a fair amount of work anyway. Then some people put a lot of work into a used car, necessary or not, simply to make it their own. And that can end-up being like a restoration project. So for a car like this, I'd think it being a total restoration project won't stop it from selling quickly.
There are probably some TGO members in or near Stockton who could take a look at the car(if they haven't already), so posting this in the Norcal section might get some help for checking it out. Of course, you run the risk of having it bought out from under you that way. Or maybe one of you has a Norcal connection through TGO who could take a look at it for you?
I have no interest in buying the car, and if it was as close as two hours away, it would make for a nice afternoon roadtrip, and I'd take a look at it for everyone. But Stockton is about 6 hours away... too far for an afternoon drive.
Hit-up the Norcal guys.
Axle/Gears: BW 3.45
Okay. Just talked to the owner.
Apparently the original owner did some damage to the engine or ran it out of oil or something and tried to get the dealer to repair it in 1991. Dealer said no. So original owner removed oil pan and Y-pipe to have a looksee and then parked it in a barn without re-installing oil pan/Y pipe/accessories and with the top down for 8 years .
The car was going to get parted in 1999 when the current owner figured he'd save it, but never got around to it.
Top is trashed, oil pan, Y pipe, rear spoiler, belts, etc are missing. So, this car has some needs which will require some cash.
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
so a motor and y pipe, which you get with headers....and prolly an interior swap and top...tires, brakes, steering parts cause you know they are dry as a bone, and probobly every rubber hose known to man......verdict: still worth it
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Worth the trouble to restore with 16K !
Car: 1994 Camaro Z28 B4C T-tops,
Engine: LT1 350 5.7L 116K
Transmission: 4L60E (being rebuilt)
Axle/Gears: 3.23 Posi
yeah i say go for it, it seems like a really goreous car, or just buy it for parts, im sure if you offered the guy 1000$ for it he would take it i would,
nice car all in all, but leaving the oil pan off for 8 years OUCH!
who knows though, you could throw a battery in it get it over clean cemet hit the key and free it up enough to blow some of that dirt and rust out of there,
put the il pan back on change the oil filter fill it up with some lightly used oil (if its blown up whatever) then spray some starting fluid into it and see if it starts and runs, that way you can check its oil pressure, and know if itll be ok to keep that motor or just scrap it,
if its good, change the gas tank and fuel pump, and you may have a good or atleast decent running iroc vert
Car: 1969 SS Camaro, or 1990 Iroc vert,
Engine: 350 and 305
Transmission: tb350 and 700r4
Car is only about 1 1/2 hours from me...Too bad...If I had a line on a stout 350 and some spare time and cash maybe, but for me I would just look for one in a little better condition...They are out there...just sayin
true, i could use it for parts, i need the doors, rims, the mirrors, the fenders, stuff like that,
mustangman65_79
08-11-2015 03:17 PM
3rdgenparts
08-06-2015 09:03 AM
