Convertible/coupe spoiler?
If the title doesn't give it away I am wondering if the coupe and convertible use the same rear spoiler center section. Specifically for a 1990. My center section is cracked and I would like to get another one. There are lots of coupe spoilers around but I would like to know for sure before I waste my time and money. Thanks, Scott.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Convertible/coupe spoiler?
For some reason, to the best of my knowledge ASC used a unique spoiler center section. Even the early Firebird with the wing style spoiler that was directly from the coupe used a unique high mount brake light...
The shape of the rear trunk is different than the rear hatch, The hatch appears to be more straight, the trunk on a vert has more of a shape.
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
How bad is the spoiler cracked ,it could probably be repaired.
Car: 89 Iroc Convertible
Ive actually seen a coupe spoiler used on a junkyard vert but they are not the same
Thanks guys. The tab is broken off one side where the third brake light lens mounts. I will have a closer look at it to see if I can just fix it.
EDIT: The stamped metal tab that the lens scres too came off. I should be able to just put it back on with some adhesive and keep on truckin. ('Vertin??)
Axle/Gears: 3.45, 3.27, 3.27
Epoxy the HMSL mount tab back on. I use Devcon plastic weld II.
Lon
Lon
