89 ASC Vert Rebuild..Fuse issue
Old 06-06-2010 | 03:07 PM
Uni-Master's Avatar
Car: 89 Chevy Camaro IROC-Z Convertible
Engine: 350 Corvette Heads bored .30
Axle/Gears: 2.77
I recently put a new engine in my 89 convertible I've been hanging on to for nearly 7 years. After about 2 weeks of driving it had a engine fire near the back end of the fuel rail. We fixed that issue now I'm having to slightly different issues.
For some reason the power lock ACC Fuse has recently popped twice it hadn't had any issues until now just curious if anyone knows a common issue area. It might have to do with the engine fire not sure.
The other issue which I've always had since we got it started and I'm sure others might have seen is the trunk fuse always blows a few seconds after its put in. Now the trunk doesn't look like its fully closed and it does have the pull down system. The trunk button that from what I've read has been changed to open the tonneau does not function and I'm assuming that both the trunk and tonneau release are on the same fuse? Can anyone help me with these 2 issues maybe there somehow related.
Here is a picture of the vert after I cleaned her up shes still very rough tho.
Attached Thumbnails 89 ASC Vert Rebuild..Fuse issue-downsized_0522001624.jpg   89 ASC Vert Rebuild..Fuse issue-downsized_0522001625.jpg   89 ASC Vert Rebuild..Fuse issue-downsized_0522001625b.jpg
Bubbajones_ya
07-06-2024 08:32 PM
MM2Robinson
10-01-2017 09:16 AM
nova983
European Region
11-02-2015 12:15 PM
TheTraut88
09-11-2015 05:16 AM
Fronzizzle
09-08-2015 12:10 PM
Quick Reply: 89 ASC Vert Rebuild..Fuse issue
