87-88 Firebird convertible 3rd brake light QUESTION
Old 10-21-2009 | 08:43 PM
88GTAvert's Avatar
The 87 and 88 Firebird convertibles used a 3rd brake light which was smaller than the 89...does anyone know what vehicle the lens for these lights was originally designed for? I would like to replace mine but theres really no info on the lens itself. "86" is the only clue...guess it was designed in 86. Attached is a pic for reference (sorry about the quality).
Attached Thumbnails 87-88 Firebird convertible 3rd brake light QUESTION-2009-073.jpg
Old 10-23-2009 | 12:39 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: 87-88 Firebird convertible 3rd brake light QUESTION
Is it the same one as a regular 87-? firebird hardtop or t top car with the pedistal spoiler?
Old 10-23-2009 | 12:55 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Unfortunately no, For some unknown reason, As far as I can tell, ASC decided to use a unique housing and brake light for under the spoiler. I am still confounded because the wing spoiler was actually a factory unit with the ends cut off and filled in with bondo, then painted to the desired color. I am not sure why ASC used a unique third brake light, the only thing I can come up with is the shape of the hatch and the shape of the trunk was different enough that the factory brake light either had a gap or it was too tight... IIRC the spoiler for the Camaro Convertible is different than the hard top/T-top cars.
Until 10 min ago I had no idea that the 1987-1988 3rd brake lights were different than the 1989.
Do you have the complete lens, or at least all of the pieces to glue together??
It may be possible to glue it together, and make a mold from your piece and then make a casting... I have the stuff here to do just that... One of the process' that we do where I work is to make small urethane castings...
It may be worth a shot...
Old 10-23-2009 | 01:05 PM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
John,
The lens on my 88 is in perfect shape. Should you decide to make a casting.
Old 10-23-2009 | 01:12 PM
88GTAvert's Avatar
My lens is in good condition, but it has small cracks in the surface of the lense where the screws hold it in place...just wanted to have a nice, new lens if possible. My tail lights look great and then I have this dull, weathered looking brake light.
Old 10-23-2009 | 01:43 PM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Hit with some plastic polish...You can find several different brands at Pep Boys etc, Little TLC and it will look great.
Old 10-23-2009 | 01:55 PM
okfoz's Avatar
I am not sure about this, but it would not surprise me if there was another car that the piece was used on. Keep in mind that ASC made the conversion for the Riviera, Corvette, Eldorado, Cavalier & Sunbird...
It is like the trim piece on the bottom of my 89 Formula 350 convertible, it is the same piece that they used on the Cavalier & Sunbird without ground effects... The difference is it is cut shorter for the F-body...
John
John
Old 10-23-2009 | 09:05 PM
88GTAvert's Avatar
Well, I researched the 3rd brake light styles for the cars you mentioned, but no luck. It seems like all of the brake lights in the 80's on those cars were rectangles or squares. The one on my car is rounded on the ends, convex, and smooth. Guess I'll give the plastic polish a try. Thanks for the responses!
Old 10-25-2009 | 01:52 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
not positive on the Firebird's and TA but the lens from the 87 camaro is from a ford mustang. (at least that is what the guy that worked at ASC in the 80's told me) 87 is supposed to be different than all of them.
Old 10-25-2009 | 06:46 PM
88GTAvert's Avatar
Thats awesome! I checked up on the Mustang 3rd brake light (79-93) and it appears to be close to the one I'm looking for! I'm going to remove mine and compare to the pics at this website (screw holes look off a bit)http://www.americanmuscle.com/3rd-brakelight-7993.html prior to ordering.
Thanks for the help!
Old 10-25-2009 | 10:02 PM
jstoltz's Avatar
check and see if maybe the mclaren mustang might be exact I think I recall him saying that but not positive so I didn't want to post it earlier.
Old 10-26-2009 | 07:48 AM
okfoz's Avatar
THe real funny thing is my 1989 Vert brake light has DOT 87 on it. So it was approved in 1987...
All I need is the trim piece that goes under the housing to the trunk and I think my car would be complete... I suspect they were made from a non UV stable rubber and they simply fell apart.
John
Old 11-23-2009 | 04:54 PM
Ragtop Man's Avatar
Been living this dream since '87 -- the third brake light lens is from a similar vintage Ford Pickup so far as I can tell, ASC used whatever was around.
I have an extra kicking around my basement. When I went to replace the bulbs (mine were toast from the exposure, long story) I had to go to the Ford dealer to get them.
Good luck!
Old 11-24-2009 | 09:27 AM
okfoz's Avatar
So the third brake lights are actually from other production cars?
It would make sense...
John
Old 11-24-2009 | 03:27 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Is the 87 Camaro's Third Brake Light the same as on the 87 Firebird?
Old 11-24-2009 | 07:46 PM
okfoz's Avatar
I do not think the lens' were the same...
John
Old 11-25-2009 | 07:37 AM
Ragtop Man's Avatar
Yes, they tried to use as many production parts as possible -- they had already been tooled and tested, so they are ready to go and cheap to buy.
Dunno on the IROC/Camaro lenses, tho. They wouldn't want to spend a lot of money for a part like that.
Frozer!!!
01-19-2024 04:55 PM
1992 Trans Am
05-10-2023 07:19 PM
Vintageracer
01-10-2020 05:33 PM
redmaroz
08-16-2015 11:40 PM
Omega
08-10-2015 12:46 PM
Quick Reply: 87-88 Firebird convertible 3rd brake light QUESTION
