91 RS Vert 355 5 speed project
Old 10-10-2009 | 09:41 PM
Gibbyzracing's Avatar
Car: 91 RS Vert 86 Cutlass
Engine: Sbc
Transmission: T5 400 Turbo
Well here is my project I have had the car for 2 years. I bought the car with the original roller 305 sitting next to it and it had a 350 with bolt ons in it.
The car was ordered in 1990 as a B4C car. This car was used as a undercover police/detective car since it was new. When I bought the car from the detective 2 years ago it still had stacks and stacks of files in the trunk
Here is the run down of the car
91 Camaro Ralley Sport Convertable $4500 to buy car originally
4" Goodmark bolt on steel cowl hood $600
Clear Marker Lens $50
Halogen H4 Crystal Head Lights $250
New GM Top $1400
New GM Dash pad $350
1976 350 2 bolt Block 30 over $500
Scat Crank $500
X rods $200
Clevite 77 Main/Rod/Cam bearings $150
New Freeze out plugs $40
silv-o-lite 30 over flat top pistons/rings $300
Comp Magnum Cam Shaft & Lifters $175
GMPP Cast Heads with screw in studs/port/polish/springs ect $550
Weiand Tunnel Ram $500
Holley 750 DP Race Carb $850
Nos Sniper Kit $500
Nos Pressure Gauge $100
Pressure Valve for Fuel Pressure $50
Fast Flow valve $100
Autometer 2 5/8 FP gauge $75
Mr. Gasket Street Scoop $250
Fluid Dampner Balancer $175
Barry Grant Fuel Pressure Regulator $150
Holley Blue Elect Fuel Pump $75
Jegs Shorty Headers $110
2.5" Flowmasters $200
Mallory Unilite Distributor $200
Chevy Dress Up Kit $200
Borgwarner T5 Trans
New Flywheel $150
New HD Clutch Kit $150
Fake Braided Hose kit $30
Billet Aluminum Gauge Bezel $50
Jegs On/Off Switch $30
Billet Alum Catch Can $100
Autometer 5" Tach $150
Autometer tripple gauge pod on A pillar $75
Faze oil/temp/volt gauges $100
7.5" 10 Bolt Rear End Housing $250
Posi Unit $350
342 Gears $150
Old 10-10-2009 | 09:42 PM
Engine: Sbc
Re: 91 RS Vert 355 5 speed project
Nos Kit $500
Steel Goodmark Cowl hood $600
Clear Marker lights $50
Old 10-10-2009 | 09:44 PM
Engine: Sbc
New Top on $1400
ON/OFF Switch for back of car $30
Blue Alum Catch Can $75 when I bought originally for Malibu
Car Show Last year won first in f body class
Old 10-10-2009 | 09:45 PM
Engine: Sbc
Couple pix getting ready to pull the motor out
Old 10-10-2009 | 09:46 PM
Engine: Sbc
76 350 2 bolt main 30 over $500
X-Rods $200
Bottom end of motor
Scat Crank $500
Engine: Sbc
Heads
Cast Heads New titanium Valves 525 lift springs Screw In Studs
Roller Rockers On order Ported since pix $550
Old 10-10-2009 | 09:47 PM
Engine: Sbc
new fly wheel $150
New Comp Cam $175
Old 10-10-2009 | 09:48 PM
Engine: Sbc
Tunnel Ram(not carb Im using) $400
Street Scoop $200
Engine: Sbc
New Clevite 77 bearings $100 set
Block when right after putting new bearings in
Old 10-10-2009 | 09:49 PM
Engine: Sbc
here is a few more pix of the build
Braided Hose Kit(prolly wont get used lol) $30
Autometer 2 5/8 Fuel Pressure Gauge $75
Billet Alum gauge bezel $50
Old 10-10-2009 | 09:50 PM
Engine: Sbc
Nos Bottle FULL OF Nitrous $150 to fill
Old 10-10-2009 | 09:51 PM
Engine: Sbc
Mallory Unilite Dist $200
Fluid Dampner Ballancer $175
Napa HD Clutch kit $150
Engine: Sbc
Tunnel Ram/Carb/Street Scoop
New GM Dash Pad $350
my86bird
10-23-2015 12:20 PM
IROCtometal
09-20-2015 11:08 PM
IROCtometal
09-09-2015 10:01 AM
IROCtometal
09-02-2015 02:01 PM
FLAP
Camaros Wanted
09-02-2015 09:22 AM
Quick Reply: 91 RS Vert 355 5 speed project
