Show your trunk pics?
Car: 91 & 92 Z28 Vert
Engine: 91 305 92 383
Transmission: TCI Streetfighter 700r4
Trying to get my trunk figured out if anyone has any pics or can lead the way to a good picture of convertible trunk setup, stock, custom, whatever.
Axle/Gears: 3.45, 3.27, 3.27
Re: Show your trunk pics?
Did yours have molded carpet inserts on the sides? Starting in 91 GM went cheap and used molded carpet inserts in place of the modified plastic pieces that were used on the coupes. Pictures of mine won't help you because my 90 has the plastic trim pieces on the sides.
Lon
Lon
I have the molded pieces out of a coupe if i want to go that way love to see your trunk or know the place to cut the plastic. thanks again
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I am buying an 88 IROC vert. Is it possible to place an amp and 2 12" sub box in the convert.? In my other cars I have amps and subs but they are Hardtops and T Top cars. I want similar sound in my new vert.
maybe this will help you .. I posted this awhile back .. theres pics of the trunks in there .. the molded carpet type and the plastic type .
https://www.thirdgen.org/forums/conv...fferences.html
Engine: Cammed 6.0L LSX
Here is mine. Two 10" Memphis Audio woofers, a nice 1000 watt Memphis Audio amp, custom enclosure for the woofers:
Car: 92 25th Anniversary RS, 86 coupe
Engine: 305 tpi, 305 carbed
Transmission: 700rt
Thanks Blue Zee. I currently have an 850 watt amp with two 12's in both of my regular Camaro's. My next question is do you think I will need a larger amp because I don't have the hatch in a convertible and essentially have a more conventional trunk in the convertible.
Thanks! The way I have the amp lets me fold the top down like normal. It doesn't affect it in any way at all. In fact the rear bow of the top slides in right behind the amp.
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Nice set-up BlueZee28! Makes my little tube feel a little inadequate.
Car: 88 iroc vert undergoing resto
Engine: 5.0 tpi
Transmission: beefy 700r4 rdeglcltch vetserv t/go
Axle/Gears: g92 b/w
i was thinking of getting one of those bass tube is it internaly amplified? is it loud enough top down rear seat up on the highway
Car: 1991 Vert Z28
Engine: 305... LS1 waiting to drop in
Transmission: 700-R4... soon 4L60E
Axle/Gears: 3.08 posi nine bolt
Axle/Gears: 3.08
Again, don't buy this type of subwoofer if your goal is to knock out your neighbours dentures.
It's also has a remotely operated level, phase, and crossover frqz . . .
Regarding the trunk carpet, I've never seen another one with anything but black. It's pretty much the standard carpet that's throughout the car.
Hotrodboba400
12-10-2019 07:07 PM
Glowsock
09-05-2015 07:48 PM
