Are these wiring harnesses the same?
Old 03-08-2009 | 10:30 PM
WV92Camaro's Avatar
I am in the process now of replacing my complete dash harness in my 1992 RS convertible as the previous owner had destroyed the original by cutting and splicing the harness in so many places that I can't recognize which wire goes where. I recently bought a complete dash and uncut harness from a 91 camaro online recently but don't know if it came off a convertible or hardtop. When I compared the harnesses this morning it looks like the factory harness has more wires on it or someone has added some at one time or another.
My question is : Is there any major difference in the dash harnesses from a convertible verses the harness from a hardtop? Will they interchange?
My second question is : Does anybody make a large color coded wiring diagram that would be easier to read and understand rather than the one shown in the factory shop manuals?
Any help would be greatly appreciated as the car has been sitting for almost 2 years now and if it doesn't get repaired soon it may sadly have to be scrapped and I don't want to see a good car get done that way just because of a wiring problem.
Thanks again.
Lewis
Old 03-08-2009 | 11:29 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: Are these wiring harnesses the same?
Hard to tell if it gonna be different. You dont metion if the 91 was a RS also or a Z28, Did it have power windows,etc..
Old 03-09-2009 | 05:07 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
it should be the same if it came out of an identically-optioned car. The only difference I know of between a vert and a coupe is some modified wiring for the rear hatch release, ASC used the factory power hatch release wiring and modified it to release the tonneau cover instead of the trunk lid.
crt454
Interior Parts Wanted
06-23-2017 02:25 PM
TheJoeY88
12-31-2016 07:30 PM
stalkier
12-06-2015 11:25 PM
g.l.mos
08-22-2015 12:02 AM
stalkier
08-21-2015 01:54 AM
Quick Reply: Are these wiring harnesses the same?
