Will this roll bar work with my camaro?
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
http://store.summitracing.com/partde...5&autoview=sku
Will that work? By work I mean look like it would protect me? Will I be able to move my top over it with no problem? Yes I did a search I am just clarifying.
EDIT: I just read that it will need to be shortened. Does anyone know by how many inches it needs to be shortened?
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Re: Will this roll bar work with my camaro?
Well I was looking at getting a 2-point when I was considering putting in T-tops. Basically everyone that posted, told me it would offer little protection in a roll over but better then nothing.
1 Post
Car: 92 Z28
Engine: Boosted LSX
Im not usually the one to say use the search feature. BUT thhis question has been answered a dozen + times here.
The HOOP only would prob. still buckle over if you did happen to flip the car. Your much better off doing something like I did. or others.
ANY roll bar or Cage is gonna need alot of cutting, tube notching , fitting and welding.
Heres a few links and there are a ton more if you search roll bar in this section.
http://www.cecoatings.com/images/Car...t%20pics/Cage/
https://www.thirdgen.org/forums/conv...light=roll+bar
https://www.thirdgen.org/forums/conv...light=bar+roll
Engine: 355/350
I did use the feature but it didn't necessarily answer my question. I have a better chance of dying in a head on collision than flipping my camaro. I am only putting it so it looks safe for my mom. How much modifying will be necessary when installing it if I just want the hoop?
1 Post
Car: 92 Z28
Engine: Boosted LSX
How skilled are you? Can you measure? Cut? and weld?
If yes to all 3 you should have no problems.
If no to any of them. Take the car to a chassis shop or someone you know and let them do it.
Or just buy the HAWKS style bar its bolt in.
Engine: 355/350
I cannot weld but my friend works at Midas and he can weld it for me. Can I get a link to this bar? I can't find it.
1 Post
Car: 92 Z28
Engine: Boosted LSX
Not worth the $ if you ask me. But then again thats because I can weld etc.. and put a roll bar in.
but this is what Im talking about.
http://www.hawksthirdgenparts.com/ca...elightbar.aspx
Engine: 355/350
1 Post
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
dont bother, IMO the summit one would look like crap!
1 Post
Car: 92 Z28
Engine: Boosted LSX
id have to agree with brennan. If you do just a Hoop its gonna look goofy.
Id at least do the 6 point roll bar setup. Put the side bars low and they will be outa the way anyway. Will look good and please your mom.
1992rs/ss
05-19-2020 07:02 PM
9192camaro
16
02-03-2019 12:21 AM
