what holds the top down on the sides right above the windows???
I recently had my top put on but I notice on the sides above the driver and passenger window there is nothing really holding it down. I mean if someone wanted to they could just reach right in! So I know I have to be missing something just wondering what it is... Its on an 89
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
Re: what holds the top down on the sides right above the windows???
there is a cable on each side that runs that goes through a little sleeve in the top above the window. yours may be broken or just has a lot of slack. i think top down solutions may sell them.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
when putting the top up, there will be slack. But once its latched down, its all very tight.
There is a 2nd bow, right above the middle of the window. Is there one on yours? Maybe your missing a bow?
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
