How to put top down??
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Ok guys I know this a silly question but how do yu put the top down on a 87 Iroc? I just got this car and I do not know alot about it yet...Thanks alot!!!
JMTX81 (09-15-2021)
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: How to put top down??
1) Unhook the latches from the front of the top located above the visors.
2) Pop the rear of the top with the latch located above the rear speaker on the drivers' side.
3) Lift the back of the top up and hit the electric toneau release switch which should "click" kinda like a door lock and enable you to lift the toneau cover.
4) With the toneau cover fully open, pick the front of the top up and slowly fold the top down into its compartment. You may have to manually lift the #2 bow as you are folding the top since the pieces that fold that bow upwards in order for the top to open are usually broken. You can get new ones from Top Down Solutions if it really bugs you.
5) DO NOT FORCE ANYTHING! If it doesn't fold right, back up, regroup and see if you're doing something wrong. (Ask me how I know ...)
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
ALSO ROLL DOWN YOUR WINDOWS FIRST!!! or open BOTH doors.
John
John
Car: 1988 convertible Z28 I think
Engine: 30 over 350 carbed and HEI
Transmission: T5 5speed
Axle/Gears: 9bolt 327posi disk brakes
His 87 may not have the electric toneau release my 88 doesn't.I don't even have the manual release handle,it's missing.You may have to look inside the interior panels and pull the small release cable by hand on each side.Hopefully you have all the parts.
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Hi NY87Iroc. In the link below, scroll down to my post (post #32 in that topic). You will get a great detailed description, a further link with pics, and more great tips and tricks for operating your top.
https://www.thirdgen.org/forums/conv...upplement.html
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Axle/Gears: 3.45, 3.27, 3.27
I'll drive at night with the top down and windows up. The heater on high gives a nice cocoon of warmth even at freeway speeds.
Lon
Lon
Axle/Gears: 3.08
Same here. I bought my convertible to drive with the top down, and if that means occasionally putting the windows up at times to be comfortable in the ridiculously short Canadian convertible season, then I will.
To me, doing that is still a better alternative than putting the top up earlier than you have too. But, I guess some people are more self-conscious than others.
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
You only have to put the windows down a few inches before lowering the top. Here's why; the side rails that seal along the top of the window will catch on the rear corner of the window as you try to lower the top. If you force it down you'll wind up breaking or bending those formed rods that lift the #2 bow while the top is lowered.
Lon
Lon
Car: 1991 Z28 Convertible
Transmission: 5 Speed
When I first got mine I bent the small round bar located just above the back seats. When lowering the top, just watch those and keep them straight and everything will fit perfectly.
I just got a 91 RS with an ASC conversion. I actually have the written instructions. I have tried several times to put the top down, but it won't go all the way down. It is above where it should by by about 5 inches. It looks like a bar is running into the plastic pieces that are on the walls by each seat. It is like that on both sides. Do you have any suggestions?
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
Look at the schematics in the sticky post at the top of the convertible thread. See if you can identify the part you think binds and we can help you out better. My top is always slightly above but 5" sounds like a problem.
Lon
Car: 89 Iroc Convertible
Is your rear set down when you're lowering the top? Raise the rear seat back and see if the top hits the rear seatback. If so, that along with the other symptom you're describing tell me that the rods I call "Flip rods" are either broken or missing. These rods are supposed to lift that #2 bow. If the bow isn't raised as the top is lowered the top will fold up short and not stow properly. The top will stack up incorrectly and not allow you to close the tonneau cover. The #1 bow is the one with the handles that latches to the windshield. They are numbered #1 thru #5, with 5 being the one with the post that latches to the tonneau. If so, until you can find replacement rods you can just lift the #2 bow as you're lowering the top.
Lon
Lon
That was perfect. Thanks a million! It was a little tough, but I finally got it. The guy I bought it from has a about five convertibles, but never puts the tops down. It looks like it is just a little rusty and maybe just using it will eventually make it easier. I did not see anything that looke bent or broken.
John
John
Hi Lon
I just looked in my Chiltons. I think I have identified those flip rods as possibley being the No. 2 bow acuator. In my book they look fairly straight. Both of mine are no longer straight. Do you think I am on to something?
They are not straight. I'm attaching a picture of them. I no longer have any available. One of these days I'll get the time to set up my tooling and manufacture them again.
Lon
Were these flip rods used on all vert tops from 87-92 or just the later ones?Reason I ask is that in my 89 camaro gm shop manual it does not show them in the diagram of the convertible top
Those flip rods are essential. When I first got my vert, I thought they were spring loaded as mine was bending when I tried to lower the top. Once I looked closer and realized they were not supposed to, my top closed correctly. Passanger side was missing buy I found one and installed it. As long as those stay straight, the top should close well, if they bend, it changes the dynamic of how the top closes and you will not be able to close it. So, while closing the top, watch those bars and DO NOT let them bend.
Aw man. This post was resting so peacefully for a little over two years and you had to wake it up.
Lon
Lon
Here is a link to the Tech Article I wrote back in 2001 that is posted here on TGO to see if the Flip Rod exists on your convertible:
https://www.thirdgen.org/tech/fliprods.pdf
Here is a link to the Flip Rods that are on my web site:
http://www.top-downsolutions.com/Bod...product_id=226
Lon Salgren
Hi, I have a 1987 convertible where will The manual release handle be located??
There should be 2 loop hooks that stick out from behind the rear part of the back speaker panels
Ok thank you, I see one only by passenger side the one behind drivers side looks like has a cable going down under the carpet, wondering if there should be a release handle somewhere...
There is no handle to pop the tonneau.Its normally released by a switch.The loop cables are the backup method.
For the life of me, I cannot find those manual release cables. I have searched all over the internet and youtube (which is also the internet) to find a picture or video of them, but i have not found a thing. Can someone help please.
I decided to take the panels off and yes, they were hidden behind the speakers. Those little sneaky boogers. I had to hurry because it was supposed to rain last night. I popped the fuse by trying to plug my charger in the cigar lighter and my top has been stuck down for a couple days.
Thanks again.
1992 Trans Am
05-10-2023 08:19 PM
1990, 91, alllante, cadillac, camaro, convertable, convertible, iroc, manual, manually, put, suppliment, top, updown, z28
