88 convertible rear spoiler
Old 02-22-2008 | 09:15 PM
11sORbust's Avatar
Mine is missing, the center anyways. The odd part is I have the sides that run along the quarters. They just happen to stop about 6"-8" from the end of the trunk. Was there two different spoilers for convertibles? Unless mine is a 5 piece, then the spoiler must fill in that bare area on the rear of quarters.
:very confused:
Old 02-23-2008 | 10:49 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Re: 88 convertible rear spoiler
Pics would help a ton..... But from your description, someone may have cut off the rear quarter trim pieces. They should run all the way to the edge of the quarter where they meet with the center trunk portion of the spoiler.
In 1988, two rear spoiler designs were used on the Sport Coupe. One is the three piece ducktail which was also used on the IROC-Z. The second is a "mini-wing" which resembles the '91-'92 Z28's rear spoiler. However, Camaro convertibles (all years) only came with the three piece. Obviously, the end pieces were NOT the same as the coupe.
Attached Thumbnails 88 convertible rear spoiler-exterior-rear-07-01
Old 02-23-2008 | 04:41 PM
11sORbust's Avatar
..they are not cut, it's molded on the end.
Old 02-24-2008 | 01:23 AM
11sORbust's Avatar
..looks like a 91-92 high rise spoiler will fit perfectly. Wonder how it would look..
Old 02-24-2008 | 04:41 PM
11sORbust's Avatar
more pics...
ASC top?
Old 02-24-2008 | 04:52 PM
tweeker's Avatar
Car: rs convertible,06 dmax,07 tahoeltz
Engine: l03
Axle/Gears: 3:42 auburn posi unit
Someone has cut the ends and shaped them and yes it looks like they had a high rise spoiler on it
Old 02-24-2008 | 09:48 PM
jeffwilly's Avatar
Car: 88 iroc convert
I agree look at the holes in the trunk. The standard holes (4) run along the edge.
Old 02-24-2008 | 09:53 PM
tweeker's Avatar
Engine: l03
Looks like some bondo popping out on the corner and the third brake pocket/wiring have been filled and removed
Old 02-24-2008 | 10:59 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Something like this but the holes in your trunk are farther apart.
Old 02-25-2008 | 12:01 AM
11sORbust's Avatar
Yeah, I know about the horrible body work. Not a big deal for me.
..since my holes are not in the same spot(as a high rise), then I wonder what spoiler was used? Maybe from a SC hard top? ..anyone have a pic?
Th latch plate, does that look the same as 89-92 ASC cars?
Old 08-15-2008 | 11:15 AM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
yes it does i have a 91 vert and mine looks just like that.. i think it would look good with the high rise spoiler u should try it.. photochop it on and see..
Old 08-15-2008 | 11:47 AM
Engine: ls1 soon
u got a lot of work in front of u to bring that car back keep us upto date with pics
Old 08-18-2008 | 10:02 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
That car had a firebird low rise spoiler on it. You can tell by how far apart the holes are and see the oval impression on the paint. That and the holes for the high rise are closer together than that.
LilHot
Exterior Parts for Sale
20
04-01-2016 05:45 PM
wbrooks63
Exterior Parts Wanted
10-04-2015 09:40 PM
LilHot
08-19-2015 11:02 AM
AkDrifted
08-17-2015 08:45 PM
LilHot
South Central
08-10-2015 04:56 PM
Quick Reply: 88 convertible rear spoiler
