Pic Of The Vert
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Pic Of The Vert
Since I'm new to this section of the forum and have been asking questions, figured I would post a pic of what I'm working on. BTW, I did get the spare back in the hole and mounted properly
Typical wear items you would expect, hole in the seat, the two top/windshield trim is cracked. It is a northern car and does have some rust. I started tackeling that today. Will have to replace the left front fender, right rear quarter, patch a spot on the floor, possibly the rear bumper mounts. Then new paint.
Engine: 350 S-TPI
I'm going to paint it red with some custom heritage stripes is the plan at the moment. I dont want to have to paint engine bay, door jams, blah blah blah.
Anything done to it.. as in mods, or list of crap I have done since I bought it 3 weeks ago?
Mods, the list is not long.. its to have a 350 block, converted to 5sp. Open air cleaner, msd coil, partial ac delete, cd deck, lowered, 3.23 gears, aluminum drums, 24mm rear bar.
Work I have done since 3 weeks ago is about a page long, and grows often, lol.
Engine: 350 S-TPI
paint on hood, clip, drivers fender is rattle can because them parts were replaced. Car had been minorly wrecked and repaired before I bought it. I'll try and pull the car in the yard next time its dry and take a picture from the roof of the house.
Condenser, lines, and Accumulator have been removed. Someday the pump and firewall box will be pulled/changed.
Engine: 350 S-TPI
http://img99.imageshack.us/img99/1143/img8184600jq1.jpg
http://img136.imageshack.us/img136/9...8185600kr3.jpg
http://img99.imageshack.us/img99/6632/img8187600ll2.jpg
AJ3 seat, driver inflatable restraint
AM9 split back folding
AR9 seat front deluxe
AU3 side door elec
A31 power windows
B18 interior deluxe
B34 floor mats carpeted front
B35 floor mats carpeted rear
B84 exterior molding
C60 HVAC Air Manual Controls
DG2 Power Mirrors, L/R Color Matching
D3W Speedo Gear
D8N VSS
E5Z Speedo Delete Adaptor
E9Z Key Speedo Delete
F41 Firm Ride Suspension
GU2 Axle 2.73 (now has 3.23)
IPC Interior Trim
J41 Disc/Drum Cast Iron (now has alumn drums)
K34 Cruise Electric
K60 100amp Gen
L03 Eng 5.0 TBI (replaced with crate 350)
MD8 Auto 700r4 (replaced with t5)
MX0 Auto O/D (replaced with t5)
NA5 Tier 0 Emissions
NK3 Soft Rim Steering Wheel
N96 16x8 Alum Wheels
OMT Tire, 235/55r16
R6V Sales Item 21
UB3 Full Cluster
UN6 AM/FM Cassette (replaced with CD)
UQ1 Radio Provisions
UX6 2 Custom Speaker
VAN Plant Code
VK3 Front Plate Bracket
V73 USA/Canada Sales
Y86 MERCHANDISED PKG, CAMARO RS
1AY Order Mod Stock
1SC Package Option 3
19C Trim, Cloth, Black
19I Trim, Black
6XW Computer Select Suspension
7XW Computer Select Suspension
8NM Computer Select Suspension
81P Wheel Color, Bright Red
81Q Molding Bright Red
81U Body Bright Red
9NM Computer Select Suspension
AU3 side door elec
A31 power windows
B18 interior deluxe
D3W Speedo Gear
D8N VSS
IPC Interior Trim
K34 Cruise Electric
K60 100amp Gen
OMT Tire, 235/55r16
R6V Sales Item 21
UB3 Full Cluster
VAN Plant Code
1AY Order Mod Stock
19I Trim, Black
81U Body Bright Red
BADNBLK
Convertibles
65
02-10-2016 03:36 PM
