Driver side window leaks when it rains.
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Did anyone else have this problem and if so what did you do to fix it? I've made sure my window is fully up and the weatherstripping is not bad. I got in my car today & the seat, door handle, and floor were all wet. Any suggestions
Thanks,
Jay
Thanks,
Jay
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
I think there is an adjustment inside the door that will change the tilt of the window when it is all the way up. This would put more presure against the seal to help stop the leak.
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
have you tried opening the door and putting the window up than? Thats what I tried and it brought the window up just enough to stop the leak. If your window motors are worn out than they may not give enough force to seal the window with the weatherstripping. just my .2
Car: 1991 Z28 Vert
Engine: LT1 350
Yeah I tried to open the door to make sure the window it goes all the up way and it does. I just replaced the window motors about a week ago and everything else seems to be fine. So as of now I have no idea.
Jay
Jay
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
