polish the plastic window?
Old 03-30-2006 | 08:51 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Anyone try polishing the plastic window? If so did work so that you can actually see through it? And was it worth it? I can just make shapes out of my window its terrible.
Old 03-30-2006 | 11:23 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Yeah, I tried that. My window was really badly burned so I figured I'd try some elbow grease with some plastic polish to see if I could get it clearer.
No dice.
If the window is clear already, I cannot verfy that it makes a difference or not. Some say it does.
Old 03-31-2006 | 12:13 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I tried it, didn't work well. I even tried sanding it with 1500 grit and then polishing it, didn't work well. I'm convinced that you must replace the window.
Old 03-31-2006 | 01:14 PM
FordGirlGoneBad's Avatar
Car: '87 Z28, '00 T/A M6
Engine: 355, LS1
Transmission: 700R4, M6
Axle/Gears: 4:10 on '87, stock on others
Okay, guys -- I haven't tried this myself, but I was told that if you go to a marine/boat supply place they have a special polish just for clear plastic windshields (they're on boats, right?). I was told by a friend that it worked great on their plastic rear window -- I replaced my top, so don't need to try this anymore but would be very interested in whether it works or not. Keep me posted if you try it.
Old 03-31-2006 | 04:06 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
it's worth the effort, I managed to get out the light scratches and make the heavier ones less obvious. I used 3 separate polishes. The first one was for heavy scratches and that did a lot. The second was for lighter ones and the made the huge difference and the final was a cleaner/light polish that finished it off nicely. If you have deep yellowing or scratches they won't come out but it's worth the effort. BTW I CAREFULLY used a 6'' orbital buffer as well and that took a lot of the work out.
Old 03-31-2006 | 11:41 PM
WillSpeedy's Avatar
I bought some meguiars PLASTX clear plastic cleaner & polish. It shows a motorcycle windshield, taillights and a convertible top on the front of the bottle then shows a boat on the back. I have a mothers powerball I think I will try it out soon. Maybe this weekend. I'll let you know how it works.
Old 04-02-2006 | 06:55 PM
WillSpeedy's Avatar
I used the polish and powerball. It turned out not too bad. It definatly made an improvment over before. Check the pics.
Attached Thumbnails polish the plastic window?-plactis-polish2.jpg   polish the plastic window?-plastic-polish1.jpg   polish the plastic window?-plactic-polosh3.jpg
Old 05-19-2006 | 10:55 AM
dirtfarmer's Avatar
Car: 1991 convertible RS
Engine: Lo3 305 TBI
Transmission: MD8 700RV
Axle/Gears: 2.73OEM to 3.08 posi disk underway
Hay every one....
I was filling my washer bottle and as I add the RainX I thought ....
If this stuff is good for the glass. What would it do for the plastic?
So I did a test on a small spot in the corner. Wow...It cleared up the fog in the plastic a lot. My test spot kept getting bigger and bigger.......until I had the whole window done. I just rubbed it in an buffed off the excess. Easy.
The window looks much better and I can see out the back. The RainX stuff I was using is the concentrate.
What do y'all think?
Dirt
Old 05-19-2006 | 11:16 AM
Engine: 355, LS1
If it works I'll game to try it. One of my third gens has the hard plastic rear window and the other has the sloppy soft plastic (brand new) -- I can't see crap out of either one, so anything is better than the present condition.
Old 05-22-2006 | 06:03 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
My past experience with convs is that I would replace the window 2 or three times times for every top replacement.
I tried most everything to try and preserve the plastic. I could keep scratches off with canuba wax but nothing prevented the yellow.
Exc covering the window in the sun of course.
Old 05-22-2006 | 06:33 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
just dont do what i did, and accidentally spill WAX on it and then rub it in
thats why i had to get a whole new top, i couldn't see crap out of it after that
Old 09-10-2010 | 11:25 PM
stielow775's Avatar
Re: polish the plastic window?
Just tryed the meguiars stuff and it made my plastic back window look darn near close to new. I still have the original top so i didnt think it would do much. The meguiars plastic-x works beyond good. I just wiped it off with a wet microfiber cloth to get off any dust and used a super soft towel, rubbed it in and then buffed it out going back to forth.
Looks killer well worth the money.
Matt
Old 09-10-2010 | 11:56 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Put my vote in for PlastX. I've also had great results.
Worked well on the fine scratches and hazing. Can help rejuvinate tailights too. It won't make things perfect, but it can make things a whole lot better.
Old 09-20-2010 | 11:24 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Engine: 305... LS1 waiting to drop in
Transmission: 700-R4... soon 4L60E
Axle/Gears: 3.08 posi nine bolt
I used this stuff on mine once back before some @$$ cut my window out
Old 09-24-2010 | 06:43 AM
JWKbride's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 305 H.O.
I have the same opinion
Old 10-02-2010 | 05:54 PM
ihatemustangs's Avatar
Car: 74 z28, 89 IROC, 98 Z28, 91Z Vert
Engine: 383, 350, 347, 305
Transmission: th400, 700R, T-56, 700R
Axle/Gears: 3.42, 3.45, 4.10, 3.08
I do this all the time on Corvettes and Antiques. I work for a high end restoration shop, and what we do is use a small buffer with a foam pad, and Meguiers number 84 polish/compound. It really clears them up over any plastic restoration stuff I have ever tried. I use this on gauge cluster lenses and lights also.
Hotrodboba400
12-10-2019 07:07 PM
Fronzizzle
09-08-2015 12:10 PM
scottmoyer
09-07-2015 07:06 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: polish the plastic window?
