third brakelight bulbs$$$
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
I noticed the third brakelight on my car didn't work so I took it apart. There is 5 bulbs and they were all burnt out. So I took one to the parts store and found that they are $9.99CAN each. Which maybe why they were never replaced by the previous owner. Is this normal or is there another alternative.
Car: '91 TA vert
Engine: turboLSx
Unfortinately that's the price of the bulbs.
Awhile ago I replaced all those bulbs with LEDs. There was a guy on Ebay that had a set of 6 (one extra) and a resistor for pretty cheap (like 20 bucks).
My bird vert tailight is the same as camaro's 87-90.
EDIt: Found the website.
http://www.custom-leds.com/
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
Originally posted by iansane EDIt: Found the website.
http://www.custom-leds.com/ [/B]
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Hey Ian, your store sells those bulbs for $11 each!!! Apparently radio shack has an equivelant bulb for cheap. I'm researching it right now.
OK, the Radio Shack part number is 272-1177 and they are $1.99 each. They are supposedly a direct replacement. Here is a link to the Radioshack site:
RadioShack.com - Cables, Parts & Connectors: Miniature bulbs & lamps: Miniature lamps: 12-Volt, 20-Watt Halogen Lamps
Axle/Gears: 3.45, 3.27, 3.27
I've started selling them too. I sell them in 20 watt and 10 watt. TDS 600260-20 or 600260-10.
Lon Salgren
Lon Salgren
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I bought a few of the bulbs that go into the side marker lights. I straightened the pins and that's exactly what the RadioShack bulb looks like. I believe they cost $1.49 for a pair or something.
Lou
Lou
Car: 1991 Trans Am Convertible
Transmission: 5-Speed
THANK YOU!!!!!!!!!!! I'm glad you posted this and I found it. I just bought a 91 Trans Am Vert. and not a single bulb in the third brake light worked. The third brake light working is a pet peeve of mine, so I was getting ready to buy them for the $8.00+ at Advanced auto. I read this and bought them at Radio Shaft for about $1.99 or so a piece. So that saved me over $30.00 Thanks again!!
Car: 88 sport coupe convert
Engine: 305 tb
Transmission: auto
Went to Radio Shack this weekend and got a bulb (272-1177). All of mine were out except one. Put the new 20w in and had someone hit the brake pedal. Man that 20w bulb got real hot in just a few seconds. Don't know if I want to run 5 of them getting that hot. I may try to find some 10w bulbs.
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Hopefully you won't be needing to go through too many of these bulbs, and you haven't caused any damage to the socket(s) either (that could be costly).
Stock replacement AC Delco 3rd brake bulb #9441724, about $10 each.
This is a halogen bulb. Try not to handle the glass with your greasy fingers when you replace them.
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
forget the bulbs, Custom LED Designs just got my kit yesterday for 4.50, put it in, and its great! looks cool too, get the deluxe kit.
Now you have a choice: Radio Shack @ $1.99 and now the LED setup for $9.75 complete. Anyone paying more has not been paying attention on this Form the price of these bulbs has been dicussed for years, I have used the Radio Shack ones for the last 10 yrs at least with no problems except normal burn outs and now I am going to try the LEDS because they are so cheap and easy to install.
Received my LED kit and installed with no problem. You just have to be careful putting the pins in, you need to spread them to fit. All in All it looks like its is worth the money $9.25 they may not be as bright as the orginals bulbs. Now you have a choice the LEDS or the Halogen.
Car: 1990 Camaro RS
Engine: 305 TBI (LO3)
Axle/Gears: 3.08
I just got my kit to try to fix my third brakelight. No idea why it wasnt working but put the led's in did some cuttin and crimpin and the lighting looks awesome. GET THIS KIT FELLOW TGO'ers.
Get the Deluxe kit and you will not have to cut or crimp anything, Its a good deal.
Car: 1990 Camaro RS
Axle/Gears: 3.08
I actually did which i will say again fit awesome but my connector that was on my car was shot so i just spliced the wiring right in. The spade connectors werent making contact on the wire coming from the spoiler.. Thats kind of what i fixed besides all of the burnt out incandescent bulbs with the led's
Car: 1987 Z28 Convertible
Transmission: 5-speed
.... or if you're into creativity and uniqueness (like me), I was able to take a pair of LED light strips (24 LEDs per strip with 1/2-inch spacing) and form two rows. So my light fixture has 48 LEDs. Works great and looks awesome.
And because this is the convertible forum, I've gotta say that this light assembly is on my coupe. My convertible's third brake light uses two #906 bulbs (it's unique to 1987) which are cheap!
Car: 1987 Chevrolet Camaro IROC-Z
Engine: 5.7 350
Transmission: 700R4 Auto
Axle/Gears: Stock 3.27, er whatever
Yeah, powerfull weak. I shoulda looked at this first. My brother just bought a '91 RS vert, and every bulb was out. Couldn't believe how expensive them bulbs were. D'oh!
