My car's RPO's
1 Post
Car: 1990 Iroc-z convertible
Engine: 305 TPI LB9
Transmission: 700 R4
My car's RPO's
I doubt they are anything special, but who knows. I bought this car for $2000 from my step dad. It needs a new top, tranny and has 124k on it. Think I got an ok deal?
AC3 : ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AG9 : ADJUSTER, SEAT, POWER, 6 WAY
AJ3 : RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AM9 : SEAT, RR, SPLIT, BACK, FLDG
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 : LOCK CONTROL, SIDE DR, ELEC
A31 : WINDOW, POWER OPERATED, SIDE
B18 : ORNAMENTATION, INTR, DELUX
B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DG7 : MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
D34 : MIRROR, VISOR VANITY
D7C : GEAR, SPEEDO DRIVEN
D8E : SENSOR, VEH SPD
D88 : DECAL, STRIPE, SPORT
E5Z : SPEEDOMETER ADAPTER (DELETE)
E9Z : SPEEDOMETER KEY (DELETE)
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
G92 : AXLE REAR RATIO, PERFORMANCE
G80 : AXLE POSITRACTION, LIMITED SLIP
IPC : TRIM- INTERIOR DESIGN
J41 : BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68 : GENERATOR,105 AMP
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NN5 : EMISSION OVERRIDE, CALIFORNIA SYSTEM, FEDERAL
NP5 : STEERING WHEEL, LEATHER WRAPPED
N96 : WHEEL, 16 X 8, CAST ALUMINUM
QLC : TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
T93 : LAMP, TAIL & STOP, SPECIAL
T96 : LAMP, FOG
UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UM6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UQ1 : RADIO PROVISIONS, FOR STEREO
UX6 : SPEAKER SYSTEM, FRT DUAL
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VG8 : VEHICLE, BUYER NOTICE LABEL
VK3 : LICENSE PLATE, FRT MOUNTING PKG
U73 : ANTENNA, FIXED, RADIO
WW1 : APPEARANCE PACKAGE(WHITE), AERO #l
W62 : ORNAMENTATION, AERO PACKAGE
Unable to locate code YA7 in our database!
YF5 : CERTIFICATION, EMISSION, CALIFORNIA
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
1AZ : Order Modification, Orders Sold (or: CUSTOMER ORDERED VEHICLE)
1SD : OPTION PACKAGE 04
11Q : MOULDING COLOR, WHITE
15P : WHEEL COLOR SILVER METALLIC (91)
19C : TRIM COMBINATION, CLOTH, BLACK (C) (91)
19I : INTERIOR TRIM, BLACK (I) (91)
199 : SEAT BELT COLOR, BLACK (91)
40U : PRIMARY COLOR, EXTERIOR, WHITE (91)
62W : TRIM COMBINATION, VINYL, LT SADDLE (W)
72W : TRIM COMBINATION, VINYL, DK CARMINE (W)
8NL : COMPUTER SELECTED REAR LEFTHAND SPRING
9NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
90A : STRIPE COLOR, ACCENT, TWO TONE, GOLD/DK AUBURN (91)
T96 : LAMP, FOG
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Not bad, your RPO list looks pretty complete. One thing I did notice is that you might want to look at the V73 RPO for the fixed antenna. That code should be U73 instead of V73.
1 Post
Engine: 305 TPI (LB9)
Transmission: WC T-5
If you like the car and don't mind putting the ~$1,500 into it, then yes, you got a good deal. It's not so much about the car's monetary value as it is how much happiness it brings you.
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
I AGREE!
I decided, yeah, it's worth it. The car is paid for and it won't need either of those things for quite a while. I think I will put back a little cash along to cover the expense when it gets here.
There's nothing like running around topless on a beautiful day!
hectre13
12-11-2023 08:14 AM
Linson
08-21-2015 02:12 PM
