what size tires?
Old 04-07-2004 | 12:31 AM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
what size tires?
can i safely put 255's on my 91 vert? and what size do all u guys and girls have on yours and does it rub? mine has 245 50 16's now
Old 04-07-2004 | 12:54 AM
bphage's Avatar
Car: 1988 IROC-Z Convertable
Engine: 350 Cam, Heads, Heders...etc.
Transmission: 700-r4 "Raptor"
it all depends on your rim size. I have 255's on 18's in the front and 265's on 18's in the rear. You can fit 275's on 18's in the rear, but may need to modify the fender lip a little if you have a large drop like my friend who has a 4" drop.
Old 04-07-2004 | 09:35 PM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
I have 275x40x17 on 17x9.5 wheels up front with no rubbing,
and 315x35x17 out back on 17x11 wheels no rubbing after some
inner fender well mods.
Old 04-08-2004 | 01:58 AM
thanks for the replys but i guess ishould have mentioded i have the stock 16 inch rims on my 91 and i want new tires for them and was wondering what size all u guys have will 255's rub up front i know they fit good in the back and can i go any wider thanks
Old 04-08-2004 | 02:29 AM
bphage's Avatar
I had 255 on 16" rims before I went to the 18" rims. I had no problems at all... You could probably squeeze 265's in the back... I am unsure of the front. I usually use kumho tires. So if you wanted 265's you couldn't use the very good, but cheaper, 712 series; you would need to use the v700 or other road racing series tire. If your car is a daily driver I would just go with 255's all the way around using the 712 series. If you don't drive it as often or just want better traction then go with v700's in 255’s all the way around. And if you go to a local tire shop, they are usually more than willing to mount a tire to see if it fits... then you can try the 265's in the rear. As far as I know the largest size you can get are 265's on a 16" rim.
Old 04-24-2004 | 03:22 PM
shipfitter_sjd's Avatar
Car: 1992 Camaro RS Convertible & 1983 P
Engine: 305 TBI & 305 4 BBL & 4.7 liter
Transmission: Auto & Auto & 5 Speed Manual
Here is my 2 cents worth....
My '92 Camaro has:
GOODYEAR Eagle GTII's
P235/55 R16
25th Anniversary rims.
Isn't the 235 the height of the tire, the 55 the width, the 16 the size of the rims, R is for radial and P is for passenger car?
Old 04-25-2004 | 02:44 AM
bphage's Avatar
Re: Here is my 2 cents worth....
Not quite; this should answer all your questions.
http://www.tirerack.com/tires/tirete...nformation.jsp
Originally posted by shipfitter_sjd
My '92 Camaro has:
P235/55 R16
Old 04-25-2004 | 09:31 AM
More To It...........
I guess there is more to it than i thought...........Thanks.
Old 06-15-2004 | 11:23 AM
irocz8868's Avatar
Car: 1988 IROC-Z Convertible
Engine: 1992 5.7 Vette Engine
Transmission: 700R4 Auto. Built
245/50/16 The 245 is a ratio of the width. The 50 is a ratio of the height. The 16 is the rim size.
Old 02-02-2008 | 01:41 AM
krs-1's Avatar
Car: 87 iroc droptop
Engine: 350 tpi
Transmission: 700 r4
Axle/Gears: 373
Re: what size tires?
mine rides on 275/40/17 on all fours with an eibach drop kit northstar camaro club minnesota chris l williams 87 iroc convert
Old 02-03-2008 | 11:13 PM
badnova's Avatar
hey lbsz28blown what inner fender mods did you do please let me know I want to do the same wheels and tires on my vert
Hotrodboba400
12-10-2019 08:07 PM
TheTraut88
09-07-2015 06:22 PM
SG91camaro
09-05-2015 11:27 PM
1Aauto
Sponsored Vendors
09-02-2015 02:50 PM
1Aauto
Sponsored Vendors
09-02-2015 02:35 PM
Quick Reply: what size tires?
