91-92 Z28,T/A,formula or 88-90 iroc
Car: 99 TA---94 toyota p.u.
Engine: LS1----22re
Transmission: T56----5speed
Axle/Gears: 4.10
Well im on the look-out for another thirdgen.
I just moved to Tennesse in November of 05' from N.C.
And well i went up to NC to get my girl and on the way back after driving for 28 hours straight i wrecked my Z28. The guy that towed it away wanted to buy it, and at the time i was so pissed at myself, and shocked that i just wrecked my baby. That i decided to go ahead and sell it.
So im looking for a 91-92, Z28, T/A, or formula.
Id prefer a 5.7,
if it is a 5.0 it would have to be a manual, or a convertible
Let me know what you guys have out there, i have couple k that i need to get rid of.
I would consider also consider a 88-90 iroc
Trey
tpi86z@yahoo.com
919-949-4503 cell number
Id prefer a 5.7,
Trey
tpi86z@yahoo.com
Want a title? Post!
Car: 88 Iroc
Engine: 5.7 tpi
3 hours from TN
1988 IROC Z28 Camaro 5.7 Tuned Port Injection Engine 700R4
Transmission less than 13,000 miles on rebuilds 2.88 ANTI-SLIP Rear
Purchased car Sept. 03, had towed to house. $1,250 car $40 tow. Got running, found that trans
was bad, had trans rebuilt, head gasket started leaking. SEE BELOW.
Mods. Mostly I went back to original, {except 20 over bore to remove eggshape. Had block
checked, heads checked, by Bill Eason}, NEW:::::::::: pistons, rings, head bolts, bearings, push
rods, rocker arms, harmonic balancer from Eason’s $500. Billet pulleys, h o water pump, MSD
coil from Summit $300. High volume oil pump and spring, all new gaskets, exhaust pipe
(manifold to muffler) from O’Reilly’s $300. U-joints replaced $75. Tires $400, carpet J.C..
Whitney $85. Seats $200, shocks, hood shocks, back window shocks, struts, alignment,
stabilizer connectors front and back $300, New mass air flow thing $135, fan switch, tps,
distributor cap, rotor $100, etc. Had local builder torque all bearings and head bolts, and other
miscellaneous work (Heath Duncan) $250, I cleaned every engine part (priceless), checked and
reused original cam, checked and reused crank(had Polished) $100, transmission rebuilt, new
high stall torque converter by Bill Lynn in Searcy $795. Had Jeff Hughes take trans out, then put
back in $250. Changed rear end fluid, added additive $50. New front rotors and pads, new rear
calipers, pads and lines $300. I kept most all receipts, and old parts. Jan. 05 car died going
down road, mechanic of 35 years stopped to help, got it started, he said distributor module going
out, replaced module in distributor next day $100. Purchased 8.5 mm plug wires 2/04/05 $50
installed 2/10/05. Purchased new radiator $125 and oil pressure sending unit 2/12/05 installed
2/14/05. 4/12/05 Air Conditioner compressor started leaking, replaced compressor, clutch,
screen, dryer, retro fit to 134 $350. 7/15 RUNNING HORRIBLE took to local shop (GREG
BROWN), they installed new tps and distributor module. $375.00 Ran O.K. a couple hundred
miles. Purchased emergency brake cables 8/15. Purchased fuel pump and new fuel tank 8/15
$300, had both installed 8/17/05 $100. New muffler installed 8/18 $150. Ran great less than 100
miles. Contacted electronics specialist in Little Rock (Dino) told me several things that
needed to be checked, gave me name Buddy Arnold of Cabot. Took to Arnold’s Auto
Center Sept. 05. They installed emergency brake cables, new fan switches, Eckland sp?
distributor module, MSD spark control, they rebuilt front calipers, installed new master
cylinder, set timing, adjusted throttle body. $1,200.00 Took car to Talladega 7 hour trip,
Oct 05 no glitches, air condition/heater blower fan went out, purchased and installed new
in Alabama. Car is now dependable, starts every time. Runs good every time. Goes
good, stops good. GOOD. This car was a daily driver at first, now it sits for 3-10 days at a time.
November 2005. Notes to purchaser. Tach off quite a bit, temp gauge off 12 degrees
(when it reads 220, actually is 208), odometer does not function properly, cruise control
and windshield washer wires cut when I purchased car, fuel gauge, oil pressure gauge and
speedometer work perfect.
Car from factory: designed to have traction from start, with the 2.88 anti-slip rear, and
fuel efficiency on highway with the 700R4 trans. Testing in late 87, early 88 compared
the IROC against mustang, firebird, etc.; Iroc went 149 mph, stopped on dime with the 4
wheel discs. Personally, I have had the car to 110 m.p.h.. Most all of my labor (many
hours), and many small parts, Mobil 1 Oil changes every 3 months, and the fact that
I rented a shop for $275 a month during project is not listed above. Do the Math.
Over $8,000 invested.
Asking $5,000.00
Asking $5,000.00
![burnout](https://www.thirdgen.org/forums/images/smilies/burnout.gif)
nhra-trans-am
Southern California Area
09-17-2015 10:16 PM
mustangman65_79
08-11-2015 03:17 PM
