4 barrels stay open all the time
Hey everyone,
Ok so my buddy told me last night that he thought it sounded like my 4 barrels were opening early. Its the stock quadrajet by the way. I was cleaning my carb tonight and noticed that they never close. What can I do to adjust this? I am not going to buy anything or rebuild anything cause I am putting in a 350 in a few weeks, I just need to know if I am gonna have to deal with it or can I adjust something.
Jay
black 85 Z28, t-tops, 4bbl carb, flowmaster 80 series muffler w/ custom tips (hollowed out cat), edelbrock chrome air cleaner, B&M Megashifter Infinity 4" 2 way front speakers and Infinity 3 way 6x9s, Alpine CDA-7863 head unit. MacEwan motorsports white gauge overlays, blue Xenon bulbs. many more mods planned (350 4 bolt main w/ holley 4160 and edelbrock performer RPM intake coming very soon)
Jay's webpage
[This message has been edited by jayman350 (edited May 16, 2001).]
Jay
Jay's webpage
Car: Camaro sc
Engine: 350 cid.
You must mean the air valve to the secondaries is open.If they're just flopping around with no tension at all,i'd say your tension spring is either broke or the set screw came loose(spring is on the left side of the air valve,you can see it if your breather is off and your looking up from the bottom of the carb.)If it's stuck ,maybe one or both of the butterflys for the secondaries are mis-aligned.If they aren't fit perfectly square in the hole ,they'll fetch up on something sometimes.If it actually is your throttle blades staying open,you got problems.Hope this helps .
86'Camaro Berlinetta SC,former 2.8,now 327 cid with 350 tpi heads(pocket ported)summit k1102 cam,305 H.O. aluminum intake,edelbrock 1405 carb,recurved HEI with accel adjustable vac advance can,rebuilt 700r with shift kit,B&M mega shifter,grant steering wheel,t-tops,american racing wheels,louvers....now if i had fresh paint,subframe conn.,cowl induction hood..sigh..
They never close??? Thats kinda confusing because the way that the the secondaris are set. MTCAMARO was right when he said that they could be floping around and you should follow his advice and if they are open constantly "flipped up" then you have a problem that i have never seen.
Just to be on the safe side if you friend said they sounded like there opining to quickly it could be because of your air filter, open eliment type dont block sound like a snorkle. How does you car run. economy/power wise?
Ok, there is a little tension in the blades but once they open they don't close like they should. I was checking it out and the arm that should bring them back to the close position just doesn't do it.
The car runs ok. Power wise it has some ***** but you know, its an LG4 in need of a tune up, bad. Economy, yeah right my gas mileage is just plain bad.
Jay
Jay's webpage
Jay
Jay's webpage
anyone else have an idea?
Jay
Jay's webpage
Jay
Jay's webpage
Ghettobird52
07-06-2024 12:18 AM
