Edelbrock vs. Road Demon
Car: 88 IROC
Transmission: auto
I have narrowed my searches down to these two. Its either the 1406 edelbrock or the road demon carb. I'm planning to use these with the performer RPM manifold on my 305. Can anyone tell me how they compare as far as gas milage, performance, and driveability in cold weather(very important here in chicago)
Mods:Hooker Aerochamber 3" exhaust, gutted kitty,
March 2 piece underdrive pullies, smog pump gone,
14x4 K&N, 3.42 gears,
Eibach springs with KYB's all around.
Appearance: Harwood cowl hood, Z-28 wing, painted black(7/20/00)-original color was light blue
*All these mods were made this year
Stock Options:120,000 miles on motor, 5spd, TBI, 305, T-tops
Run a best of 16.7 @85mph before gears
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
Go with the Edelbrock. It will run well right out of the box with no tuning necessary. You probably want a 600 cfm for your car.
i just put on a road demon on a 305 with rpm manifold.......the carb is nice but keeps flooding. i am still trying to get the damn thing tuned. i am new to carbs though...still learning
The edelbrock will require some tuning but it can be done with just a screwdriver and some patience. The road demon is going to get worse gas milage because it delivers more fuel and is setup for performance. The reason why it keeps flooding? Too much fuel and the jets are probibly too large for the little 305. I am running the edelbrock 600 on my 350 with .98 promary jets. A little lean for my taste but I still get enough fuel. I am currently getting 14-15 mpg in town with traffic. With the 305, I say go edelbrock unless you plan some huge upgrades later. The road demon will not make you car faster, it might even slow it down untill you get the proper mixture.
1983 Camaro Z28
Goodwrench 350ci V8, Edelbrock TES Headers, Flowmaster Catback, MSD 6al and Blaster 2 coil, Edelbrock Performer intake, Edelbrock Performer 600cfm carb. T5, 373 rear, Eibach springs, Cervin Vega speakers, Rock. Fos. Sub, Pioneer CD,
email-chris4421@hotmail.com
"I used to be a Mustang Guy! I didn't know the power of the dark side!!"
1983 Camaro Z28
I say go with either a Q-jet or a Holley. from my past experiances the Demon carbs and good to look at and that is about it and the Edelbrock/Carter carbs are way lean. I can say the Edelbrocks get good gas milage but performance wise at W.O.T. you will not get the gains you would with a Holley or Q-jet. The Edelbrock will get about the same gas milage as a well tuned Q-jet and the Q-jet will perform every bit as well as a Holley at W.O.T..... Just my 2 cents.
Car: 88 IROC
Transmission: auto
I think i'll go with the Edelbrock, which should be way enough for the 305. Also, there is a good deal in Jegs where i can get the performance rpm manifold with the edelbrock carb and the camshaft for about 440 dollars. When i order the package, i'm just gonna put the manifold and carb in. My only concern is, will i be able to swap all this into a 350 later on?? thanks for all the help.
Pac J
05-17-2020 10:44 AM
Night rider327
09-25-2015 04:47 AM
