Edelbrock carb opinions?
What's the concensus here on Edelbrock carbs? My 14 year old, never rebuilt QuadraJet carb is starting to get weird... Choke'll stay open too much during normal operation (making idle rough and throttle response suck), but sometimes suddenly shut all the way, SHUTTING THE CAR OFF!
The reason I ask about Edelbrock is cuz they make a nice square bore carb at 600cfm that'll mate up nice with the 7101 Performer RPM intake that I want to get. If Edelbrock does make a good carb, as I have heard before, the only question remains is... #1400 or #1406 as far as the 600cfm jobbers go.
LOL Or even more importantly, is there something else you can recommend. Mind you, I'm not looking for complete insanity, here. RoadDemon's not in my budget. I'm thinking AT MOST $300 for a good carb that works nice out of the box and doesn't need to be readjusted constantly or rebuilt within a year.
1986 Firebird, LG4 305, bored .040 over, Crane cam, Edelbrock headers, Hooker Aerochamber muffler, loud and fast.
"Gimme fuel, gimme fire, gimme that which I desire!" - Metallica, "Fuel"
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I have an Edelbrock 1406. I'd have to say it's adequate. Holds its tune pretty well, works well, no major problems with it. The WOT mixture was perfect for my application right out of the box, just had to go 1 step richer on part-throttle. If you're going to go with an Edelbrock, I'd recommend one with an electric choke.
1984 Silver Z28, 383 cid 4 bolt, ARP Fasteners, 2 1/2" Cowl Induction Hood, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Magnum Roller Tip Rockers, MSD6AL Ignition, Blaster2 Coil, Recurved HEI Distributor, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flo-Pro Twister Muffler, 4 Wheel Disc Brakes, Oil Cooler
i curently dont have a edelbrock, but would defentily buy one over a holley. holleys are so damn finikey. i havent heard anything bat about edelbrocks. i say buy an edelbrock.
when the green flag drops the bull$hit stops
350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
So... The question is, between the 1400 and the 1406, which is the better 600cfm electric choke carb for my car? If I get the carb, I'll also be getting the 7101 intake.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Originally posted by GilmourD:
Also, what's gonna happen with my computer? I've got an LG4 from 86... Is my carb computer controlled?
If I were you, I'd fix the choke problem that you're having with your computer controlled q-jet, especially if it's a daily driver and absolutely if you need to pass emissions testing. Get a Weiand Action + manifold as an improvement; you're looking at a lot less than $300 total. You'll have better overall performance and will keep it legal in case the EPA goons start looking your way.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
[This message has been edited by five7kid (edited November 10, 2000).]
just a question doesnt carter make the edelbrock carbs? If so how would the carters compare to edelbrocks?
91 RS' TBI 305
mods:
dynomax exhaust, lakewood control arms, gutted cat, pioneer deck, tbi spacer, jet stage 2 chip, K&N four inch element and open element, accel cap and rotor, moroso plug wires, msd blaster coil, bosche +4 spark plugs. Alot more mods to come!!(update 11/01/00 pulled engine
visit my page http://www.geocities.com/motorcity/pit/8410
2001 camaro SS LS1 onyx balck, SLP dual/dual center exhaust which brings horsepower to 335hp and 350ftlbs of torque, T-tops, 6 speed, Hurst shifter, cags!, power everything
91 RS' TBI 305
mods:
Engine: 383 Carb
Transmission: 4L60
Actually, according to the Edelbrock catalog, they're made by Magneti-Marelli USA, Inc.
Engine: 383 Carb
Transmission: 4L60
How old is your carb? Maybe Edelbrock recently changed their outsourcing. Or maybe Weber got bought out. LOL Who knows in this crazy world.
Engine: 383 Carb
Transmission: 4L60
Just got it in August, not a rebuild either.
Now that I look too, right on Edelbrock's square-bore carb page it says "Manufactured by Weber USA®, Performer Series square-bore carbs are all-aluminum, ball-burnished and lightweight."
Maybe they don't even know for sure who makes their carbs.
The only difference I can see between the 1400 and the 1406 is that the 1400 is "50-state street legal for all Chevrolet/GMC V8 engines, 1980 and earlier (E.O. #D-215-10)". Given the choice between the two I'd probably pick the 1406.
[This message has been edited by Apeiron (edited November 11, 2000).]
my carter has a weber stamp on the side too. i have heard that the edelbrock and carters are identical, but don't know for sure. well, cfm options differ between the carters and edelbrocks, but i hear the design is the same.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I have the setup you want and it made a huge difference in performance.
The computer is completely shut off. Car runs great, just doesn't start when it is really cold. It's like 25 degrees outside and it wouldn't start, not sure what it is, never did this before, but then again, it hasn't been this cold since I've put the carb and intake on.
when you do the swap, you need to change the distributor to a vacuum advance unit.
Also, with this setup, I ran a 14.94@91.67mph with a slipping clutch and an LG4 with 133K miles without a rebuild. My slip is here: http://www.leannrimes.cz28.com
Zepher
'86 Pontiac Trans Am WS6, 5 Speed:
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Recaro Seats,
Alpine CD+Changer,Rockford & Soundstream Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
WS6 Trans Am
[This message has been edited by Zepher (edited November 22, 2000).]
Zepher
WS6 Trans Am
Zepher,
I seems that your primary rods are just fine for good weather but they don't taper down enough to provide a really rich mixture for starting in cold temperatures. It's possible for rods to be that lean and cause hard starting, DESPITE the choke!
ECM-controlled Q-Jets are massively rich at the very end of the metering rods. I found that out when I was adjusting the lean-stop or upward travel limit of the rods. I have a post in here somewhere asking for the proper adjustment of that lean/rich stop, whatever it's called.
toronto formula
09-10-2015 07:31 AM
