Edelbrock 1407 or 1411 owners please read
Old 03-12-2002 | 09:13 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
I have a 383 stroker and am having a hard time getting my carb tuned just right. The problems are:
Intermitent bad hesitation on acceleration (not as bad as before, I put silver step up springs in)
White-ish smoke on HEAVY acceleration.
I'll be going 40 mph and romp on it and it seems like it just loads up and goes nowhere- picks up almost no speed.
Timing is at 11*BTDC, new plugs, wires and 3 month old MSD pro billet distributor with 6A box. Don't seem like it's ignition related.
Any advice is appreciated.
:hail:IROC-Z
Old 03-13-2002 | 03:26 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Sounds like it could be fuel pump/regulator related. What jets are you using?
Old 03-13-2002 | 02:32 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
.113 primary and .107 secondary.
I'm 2 stages lean accoding to the manual.
Old 03-13-2002 | 03:36 PM
JRoy91RS's Avatar
Engine: 355
2 stages lean?!? That sounds pretty big to me, even for a 383. I would check your fuel pump. Your sig. says it's stock, is that still the case? If so, it might be a good time to upgrade.
Old 03-13-2002 | 09:14 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
I believe that's where I'm headed. Not really one of those things I wanted to replace, but I guess like all things it's time has or will come and I might as well get it overwith. One thing I don't understand is the possible lack of fuel pump flow versus the jets being too big. If jets are too big causing the problem, that would mean that the fuel pump is flowing fine.
:hail:IROC-Z
Old 03-14-2002 | 01:30 PM
Fast3rdGen's Avatar
i got 113 primary and 113 secondary jets in my 1407 edelbrock on my 383. can't remember the metering rod size though. i'll have to double check and see for ya.
Old 03-14-2002 | 08:26 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
If I have my timing at 12* BTDC, it knocks, so I set it at 10 and it does ok. 10*BTDC is the limit (should burn all the fuel going into the cylinders, right?).
Plugs were very dark when I changed them indicating a rich condition.
Seems like with the timing set at a point right before it knocks, the plugs would be cleaner. AND, if I lean the carb out more, I think I will have to retard the timing again to keep it from knocking. Am I wrong? I will be so happy when I get this figured out.
:hail:IROC-Z
Old 03-17-2002 | 06:50 PM
jamesbern's Avatar
Check your accelerater pump linkage and try moving it if you have an off idle stumble. In my 383 I have 113 primary and 116 secondary jets. E-mail if you need more help. Good luck!!
theshackle
09-17-2020 09:26 AM
Thornburg
08-25-2015 02:46 AM
BlackphantomZ28
08-22-2015 02:00 PM
86IROC112
08-17-2015 03:00 PM
eightsixseven
08-14-2015 04:09 PM
Quick Reply: Edelbrock 1407 or 1411 owners please read
