How do I adjust the lean mixture screw?
I have an 85 TA with the computer controlled Q jet. I'm rebuilding it and have most of it back together. I don't see anything about adjustment on this in the instructions that came with the rebuild kit.
Car: 1989 C4
Axle/Gears: 307
If you were to pop the caps off of the adjustment screws and tune your CCQjet the advantages would be nill. The computer is responsable for controlling the mixture. I would leave it alone and just put it back togather factory set. I did pop the caps and try to tune the carb old school before and it did so little I wouldent reccomend anyone doing it.
Car: 1989 C4
Axle/Gears: 307
Hmmm, thats a hard one then. Put the screws in and bottem them out, then back them out 1 1/4 turns. That should be close to what GM set them to.
Good Luck!
Good Luck!
Car: 4
Engine: 6
Transmission: 5
The mixture screws in the front of the throttle body have almost no effect at all on anything. Their threads are very fine. Set them at about 7 turns out and leave them alone, they don't do anything anyway.
The lean stop is the screw that holds the mixture control solenoid in the bowl. Set it about 5 turns back out from all the way down.
The rich stop is a round thing about the size fo a dime that screws into the bottom of the air horn above the MCS. Set it about 3½ turns back out from all the way in.
The idle air bleed valve is a large screw-head looking thing in the top of the air horn right at the front edge of the choke blades. Set it for about a 50-60% duty cycle on the MCS test lead (30-35° on the 6-cyl scale of a dwell meter) while idling out of gear, and make sure that it stays somewhere near there when you put it in gear.
Thanks RB83L69, I'll try that and let you know how it goes. I got the carb back on and sometimes it runs good and sometimes it barely runs. Last night it ran good. Then it wouldnt even start.
