Ok so what was the deal with holley carbs and 700r4?
Car: 1989 C4
Axle/Gears: 307
I read a while back the the TV cable will not adjust or something when using a 700r4 & a Holley carb and the bracket need to be changed. I dident pay attention at the time because I dident have a 700r4. I looked in jegs and all I saw was brackets for projection units. What gives will the holley ruin my 700r4? If so how? I tryed a search on tranny, tech GE and carb. I just cant find that thread.
Yea I know a thread that borders two sections.
Re: Ok so what was the deal with holley carbs and 700r4?
If you use a Holley with a 700R4 you require a bracket (part no. 20-95) to hook the TV cable up with the correct geometry. You can probably modify the stock one and many people have.
Car: 1989 C4
Axle/Gears: 307
Thanks for the reply. Is anyone using thier stock bracket? If so how did you bend it? I have the tv cable set at a slight angle attached to the very bottem hole on the carb. Is that good enough or should I try and bend the bracket where it will set the tv cable straight on?
Thanks!
because my Camaro is dead.
Thanks!
BlackphantomZ28
08-22-2015 01:00 PM
86IROC112
08-17-2015 02:00 PM
