Air filter size???
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
Air filter size???
Ok im in the middle of getting a new air filter (k&n) and i did'nt know there was a science in picking the right size. any suggestions? everything i have is pretty much in my sig i was thinking of a 14x4 or would that be to big??
thanks
thanks
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
14x3 is the typical size. Depending upon hood clearance and base type (drop or flat), you may have to go with 14x2.
Before you spend the bucks on a K&N, consider an AMSOIL oiled foam filter. Flows like the K&N, has a lifetime warranty like the K&N, is cleanable and holds a bunch of dirt like the K&N, but filters out smaller particles than the K&N.
Just want you to make an informed decision, that's all...
1992 Trans Am
05-10-2023 07:19 PM
Brinkkl2000
08-04-2018 08:29 AM
