Plugging the Lower Vent Tubes on a QJ.
I have a QJ on my 1984 Trans AM built in California as an Export only car to Canada.
I have watched several flicks on Youtube concerning this subject.
One rebuilder drilled, tapped & screwed a metal screw into the small vents.
On the larger he used either epoxy or JB Weld. I know that in shot period of time the epoxy & JB faill & fall of.
Anyone have a better solution for these vents?
Car: '83 Firebird (T/A Clone)
Engine: 350 carbed with L-69 components
Transmission: 700R-4 w/2000 RPM stall converter
Axle/Gears: 10-bolt/3.73 ..
Re: Plugging the Lower Vent Tubes on a QJ.
I don't know what "vent tubes" you're talking about unless you're referring to the secondary metering well plugs, in which case this is the best way to plug them:
https://quadrajetparts.com/quadrajet...ug-p-2944.html
T.L.
Yes to the vents
I have done business with this company in the past for an alcohol resistant accelerator pump.
Tkx for the info
Yes to the vents
Tkx for the info
JB will release over time. Professional Cliff Ruggles uses Marine-Tex two part epoxy for a permanent fix.
https://cliffshighperformance.com/pr...ottom-plug-kit
aliceempire (09-11-2024)
I actually met this guy a couple years ago. This is THE fix for leakey well plugs on a Quadrajet...
The fellow who rebuilt the QJ in my 1972 Buick GS, uses Permatex gas tank epoxy to plug the /wells/vents
I like the plug idea. Don't the QJs have 4 wells or is what he shows in the flick newer QJs - 80's ?
