How to refinish older aluminum intake manifold
Re: How to refinish older aluminum intake manifold
The way I usually do that is with one of these. https://www.summitracing.com/parts/edl-2101
Car: '83 Firebird (T/A Clone)
Engine: 350 carbed with L-69 components
Transmission: 700R-4 w/2000 RPM stall converter
Axle/Gears: 10-bolt/3.73 ..
Blasting is the only way I'd do it...
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
media blasting is the best way. Just make sure to get the right media. Google aluminum media blast and you will see its different than sand. We used small shot in our industrial size at the foundry
T.L. (08-27-2020)
Problem of course is, corrosion TAKES METAL AWAY; and bead blasting, media blasting, glass blasting, shot blasting, sand blasting, water blasting, WHATEVER blasting, doesn't put the metal BACK. In fact it TAKES AWAY EVEN MORE metal.
If all you are is a poseur that want a nice shiny part to bolt onto the top of your nice krome motor, then blasting might be entirely adequate. But don't expect gasket surface to seal, for example, once they're all pitted and uneven. Butt if you're one of those guys that goes to "sq in of krome" shows so that all the 8-yr-olds can ooooh and aaaah over all the shiny and you can winch it up into your trailer, and you don't care if it runs or not (at least reliably enough to, say, go to the grocery store without worrying about whether there's a tow truck close by), blasting that thing in the photo is NOT A Good Idea.
No kind of blasting will make it look "factory new". At least, not on the smooth, carefully measured, machined, FUNCTIONAL, surfaces, like the mating flanges to heads carb block thermostat etc. They'll all look ... blasted, just like the raw casting parts will look. Which, again, if all you care is "look", then go for it. Put wheel clear-coat on it afterwards to keep it looking fresh maybe. But if you want to actually USE IT for something, ... not so much.
92GTA (08-27-2020)
Car: 89 Firebird
Engine: 355 TBI
Soak it in mineral spirits, then paint it with some good engine paint the color you want it.
vinny R (08-29-2020)
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
If you vapor blast it with some fine grade media it will look like it came out of the foundry and it won't look "blasted" like if you do with dry media. I was skeptical but I have watched some videos on youtube of a guy vapor blasting something and it has amazing results. I plan on building my own vapor blaster to replace my dry blaster in the future.
I sought out an early version of this intake as it’s period correct.
I did valve seals a few weeks ago and didn’t bother to paint the flaking valve covers as new paint on them would only make the rusty block look that much worse.
Thanks all for your input. I spoke with an acquaintance in the auto body business, much like sofaking he’s not a proponent of media blasting as the mating surfaces are easily compromised.
He suggested taping the mating surfaces and using red scuff pads to remove the surface corrosion, then mineral spirits and paint to seal the aluminum. I’m not after bling, so depending on the finished product I might just seal it in clear.
thanks again for your input.
dmccain (08-28-2020)
You could have it powder coated. And that place will do the cleaning first. How they actually prep the surface, I can't say.
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Clean and paint is the way I went. I taped off the gasket surfaces and used Rustoleum Industrial Coating line, tall silver cans, the color is aluminum. It sure does look like finish aluminum! It dries to a nice sheen, not gloss so it is hard to tell it is paint I have had mine on the car for a year now and the paint still looks great, no yellowing and nothing flaking.
Before
After
Before
After
The following 2 users liked this post by vinny R:
NoEmissions84TA (08-29-2020), theraymondguy (08-29-2020)
I started cleaning up the manifold with the red scuff pads by hand, and realized how much I didn’t enjoy that (twenty years as a heavy equipment mechanic, your elbows only can take so much).
lets automate the process.
I cut the shaft off of an old screwdriver, and cut a 1” grove into it to receive the scuff pad. This provides a pencil like abrasive that worked brilliantly to get into the small spaces and clear out all the corrosion, without removing any of the aluminum. I used a light degreased sprayed on the same “roll” and the intake afterward which really cleaned up the part.
before
after
A guy could almost leave it as is and clear coat it...
but he won’t.
I’m well pleased with it for now in its new duplicolor high performance wheel coating. A bit of lipstick to be sure but hey, it’s going on an LG4, so it was bound to be more show than go anyway 😀
Guess this means I’m painting the rest of the engine thus winter.
before
after
but he won’t.
