TV cable geometry bracket fix for non ccc carb
i’m already pretty deep with the shiny penny invested to back out so please don’t encourage me to back out. i heard that even though the tv cable will still fit in the old bracket, it’ll put it in an angle making the adjustments useless. any diy mcgivering or jury rigging that will work or do i need to spend the money? if so where can i find a bracket cause all i’ve found is the adapter to the pivot itself which i already have.
Car: '83 Firebird (T/A Clone)
Engine: 350 carbed with L-69 components
Transmission: 700R-4 w/2000 RPM stall converter
Axle/Gears: 10-bolt/3.73 ..
Re: TV cable geometry bracket fix for non ccc carb
What kind of carb? ...
There's a recent thread on the subject here:
https://www.thirdgen.org/forums/carb...installed.html
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BT0D stage 3 w/22oo
Axle/Gears: 3.23 posi disc
I would encourage you to spend the money if you want a properly shifting system. I used this one from Bowtie Overdrives: https://www.bowtieoverdrives.com/cat...php?ITEMID=213
