carb swap engine light trouble
Car: '91 firebird
Engine: 350 4bbl
Transmission: t56 6 speed manual
Axle/Gears: limited slip, 3.73 gears
hey guys, i have a '91 firebird that was a 305tbi that i swapped to a 350 4bbl and mechanically it runs and drives fine but the engine light is always on because the fuel injection stuff is no longer hooked up and i need to get rid of it to pass inspection. so is there a way to trick the computer into thinking its still hooked up? any help would be appreciated
Re: carb swap engine light trouble
Car: '91 firebird
Engine: 350 4bbl
im in PA and am pritty sure that they do plug it in otherwise i would've already done that. and ya i already tried pulling the computer and it still stays on. anyone else from PA on here that could tell me for sure?
Car: '91 firebird
Engine: 350 4bbl
also im in lehigh county pa wich is a lil more strict with this crap than other counties
Call them and ask what sort of testing will be done on it. Thats what I did. My county just wanted to see the cat converter on there via a large mirror they roll under the car....then they stick a sniffer in the tail pipe. Thats it. I spent the nine bucks for the testing and used it as a tuning aid. Mine has antique tags on it so i never planned on using the test for regular tags, but its good to know that i have a car that is a federal violation of the clean air act, but can still pass emissions
xbazzarex
08-27-2016 07:18 PM
