Carb ID
Car: 1984 Camaro Berlinetta
Engine: 305 H.O.
Transmission: TH-700 R4
Carb ID
I have an '84 camaro berlinetta with a 305 H.O. trying to figure out where the engine and what not came for. The carb is a Quad and has 17083204 1225 HZJ stamped on it. Any help?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Received 1,721 Likes
Re: Carb ID
If the engine is actually a HO, it of course didn't come in a Berlinetta.
That's one of the carb numbers for 83-84 305s. Might or might not be connected with the engine. Engine might be from Mars, carb might be stock from the LG4 that might have come in the car.
Re: Carb ID
Lots of carbs w 83 part #s were used in 84.
4th digit is part of the model #. 702 = 4M (4M is Q-Jet, no prefix is the original pre-emissions version); 1705 = M4M ("modified" 4M: heavy emissions crippling, pre-computer); 1708 = E4M ("electronic" 4M)
5th digit is the FIRST year in which that exact model of carb was used, which sometimes has been carried over to subsequent years when the calibration needed no further changes for the application.
Long and short of it, that may well be the OE carb for the car.
Car: 1988 Camaro
Engine: 2.8 to 383
Re: Carb ID
Not trying to hijack a thread, but I have often wondered what the q-jet that was on mine when I bought it came out of. It is stamped 7045184-K6
Some info I found from oldengine.org below :
You can usually find the carbs casting number and date code on the driverside of the carb stamped vertically.
A typical stamping;
7045213 YA
101 5
70 = Rochester products division#
45 = Production year, 4=1970's, 5=specific year, 1975
2 = Carb ID, 2=49 state Q-jet
1 = Division, 1=Chevrolet products
3 = Tranny ID*, Even number=Automatic, Odd number=manual
101 5 = Julian Date Code, Friday April 11 1975
YA = Engine assembly plant
# Carbs starting with 70xxxxx are pre-1976. Carbs starting with 170xxxxx are 1976 onwards.
An important note: Primary metering rods are different lengths for the two units, both rods are available from GM, and the new-part part numbers correspond with the carb. Rods whose p/n starts with a 7xyz are for the 70xxxxx carbs, and p/n 17xyz are for the 170xxxxx carbs.
* tranny ID is not cast in stone. This particular example was original equipment on an automatic equipped pickup truck.
Production Year
15 = 1960
19 = 1961
20 = 1962
2x = 1963-1969
3x = 1966-1967 A.I.R. equipped vehicles
4x = 1970-1975
5x = 1976-1979
8x = 1980-?
x=last digit of model year
Carb ID
0 = 49 state mono-jet
1 = 49 state 2bbl
2 = 49 state Q-jet
3 = California mono-jet
4 = California 2bbl
5 = California and high altitude Q-jet
Product Division
0,1,2 = Chevrolet
3 = Cadilllac
4 = Buick
5 = Oldsmobile
6,7 = Pontiac
8 = Non-GM, possibly Mercruiser Marine
9 = Special
Julian Date Code
From our above example code;
101 = Day of the year (1 thru 364/5)
5 = Last digit of manufacturing year. (0 thru 9). Utilize carb id for 60's, 70's, or 80's.
Some of those multiyear calanders with a look-up table have the Julian day of the year on them. If not, you'll just need to count out the days.
Engine Assembly Plant
YA = ?
FJY =?
Examples
Our example carb, 7045213
Is a Rochester carb, for the 1975 model year, 49 state (federal) Q-jet, Chevrolet Division with supposedly a manual transmission.
What it was originally installed on was a non-emmisions controlled 1975 3/4 ton Chevrolet Pickup truck with a 350 cubic inch engine and an AUTOMATIC transmission.
How about another? 17083222
Date Code 0183
Is a 1983 model year, 49 state Q-jet, Chevrolet division with an automatic tranny.
Manufactured on the 18th day of the year, in a year ending in 3. For, January 18 1983
Originally installed on a 1983 1/2 ton Chevy Pickup with a 305 and automatic tranny.
And one more for fun, 7043114
A 1973, 49 state 2bbl , Chevrolet division, with an automatic tranny.
Originally installed on a 1973 Nova w/350 and automatic tranny.
Remember to employ all safety precautions when working on any vehicle.
This information is only intended as an overview and may not include all the necessary information, data, or facts to complete the swap.
Remember, every vehicle is unique, and research for your particular vehicle is recomended.
A typical stamping;
7045213 YA
101 5
Production Year
15 = 1960
19 = 1961
20 = 1962
2x = 1963-1969
4x = 1970-1975
5x = 1976-1979
8x = 1980-?
Carb ID
1 = 49 state 2bbl
2 = 49 state Q-jet
4 = California 2bbl
Product Division
0,1,2 = Chevrolet
3 = Cadilllac
4 = Buick
5 = Oldsmobile
6,7 = Pontiac
9 = Special
Julian Date Code
YA = ?
FJY =?
Examples
Date Code 0183
Re: Carb ID
And now that I just took that information above and decoded the carb that actually came on the car when I bought it last year explains why it ran like a 3-legged dog. Carb decodes as follows:
Rochester
1975
49 state 2-bbl
NON GM (possibly mercruiser marine)
automatic tranny
Rochester, NY
Build date 8/20/1974
It's a 2bbl carb that came out of a damn boat built in 1974!...LOL
Rochester
1975
49 state 2-bbl
automatic tranny
Rochester, NY
Re: Carb ID
Is that kind of information above widely available? I ran acrossed it litterally on accident. If its rare info, then might be a good sticky
