Fuel sending unit help
Car: 1986 Pontiac Firebird s/e
Engine: 305 Chevy
Axle/Gears: 2.77 for now
Sirs,
Does anyone know how to get a new fuel sending unit for my 86 Pontiac Firebird vin code H 305 Quadrajet? The gm part # was 25090908. The dealer discontinued the part. You can only get the sending unit in the fuel injected cars now.
Re: Fuel sending unit help
Heres one...
http://www.partsgeek.com/3c8wz8h-pon...l+Sending+Unit
It appears this one is for FI, but IIRC, you can easily make it work as you only need the sender portion. Someone correct me if im wrong, but I dont think so...
Both of the ones linked above are for the electric fuel pump in tank.. If your running only a mechanical block or external pump, you'll have to extend the pickup tube down to where the in tank pump woud have sucked fuel from..
Example: https://www.thirdgen.org/forums/carburetors/374139-carb-gas-tank-pickup.html#post2990582
1Aauto
Sponsored Vendors
02-28-2018 02:40 PM
1Aauto
Sponsored Vendors
01-16-2017 01:05 PM
1Aauto
Sponsored Vendors
03-03-2016 11:21 AM
1Aauto
Sponsored Vendors
02-17-2016 11:36 AM
