Carb and TH350 cable brackets
Car: 1989 Camaro RS
Engine: 350 TBI
I'm going to be using the performer intake for 87-95 cast iron heads, a 1406 carb, the B&M adjustable kickdown cable for TH350 and I wanted to know if I could use my stock TBI and 700r4 bracket or what aftermarket bracket to use with my set up.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Not completely sure if the stock TBI bracket will bolt to the intake like it did the TBI intake, but if you can get that to happen (high likelihood), then you should be fine. I'm not familiar with the B&M adjustable cable, but I'd guess it has a pretty universal mounting feature.
Car: 1991 Chevy Camaro
Engine: 305 cu. in.
Transmission: clunky 700 r4
Axle/Gears: 2.73 ?
Re: Carb and TH350 cable brackets
you may find that your cables wont reach with the tbi bracket, there are aftermarket brackets that will bolt to the carb they are adjustable, Holley makes one, specter makes one, and I do believe Edelbrock makes one.
Engine: 305 cu. in.
Axle/Gears: 2.73 ?
[For Sale] Stock LS1 heads castings #806 (low miles)
FueledSoul
LSX and LTX Parts
10-01-2016 01:27 PM
John Hagan
Interior Parts Wanted
02-07-2016 10:06 AM
