holley street avenger dual feed what fuel line?
Car: 1991 Chevy Camaro
Engine: 305 cu. in.
Transmission: clunky 700 r4
Axle/Gears: 2.73 ?
I have a holley street avenger carb with dual inlet that was given to me, what fuel line to the carb is best to use? that chrome one from mr gasket leaks everywhere. also if anyone is using a holley fuel pressure regulator what kind or where did you get the return fitting for the 5/16 line ? the brass one from the parts store is to short and leaks because it wont clamp properly.
Engine: 305 cu. in.
Axle/Gears: 2.73 ?
Re: holley street avenger dual feed what fuel line?
also the mr gasket fuel line runs smack into the 5/8 heater hose return barb
