92 Camaro TBI to Carb, Throttle cable/bracket?
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
I took my 92 camaro from TBI to carb, I am at the point I would like to hook up the throttle, but the cable from the TBI is too long and the bracket wont work. Can anyone link me to a product that I can buy to correct this? I need a new cable and a bracket that will work (also a return spring). My cable was 28 inches long, anyone know how much shorter I will need?
Car: 1992 Camaro RS
Engine: 350 Carb'd
Re: 92 Camaro TBI to Carb, Throttle cable/bracket?
Come on now someone has had to take their 92 back to carb and ran into this same issue!
Your cable is FULLY compatible with a carb. You just need the right bracket to get the length to match up. I've used a bunch of different ones over the years. If I tell you that a cheap Spectre bracket woked best you'll probably kick me right in the groin. There is NO WAY such a cheap POS bracket belongs under that hood. Fortunately, there are many different ones to choose from.
I'll also mention that it's important to have the throttle cable stud in the proper hole on the throttle arm. This is the proper location for that stud on a Holley-style throttle arm:
Car: 1992 Camaro RS
Engine: 350 Carb'd
Which bracket will work? Seems like my cable is way to long no matter what I do. I've modified my bracket no good I've used a older version no good. Just looking for advice on which to buy?
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
I used this bracket, that you can get from Summit or Jegs, and utilized the factory cable, it has plenty of adjustment and should work great for you as well.
http://www.summitracing.com/parts/aa...4215/overview/
This unit is for the Lokar cable but they also produce it for the standard TBI cable.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/post...32-post24.html
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
This is my setup, using the factory T.B.I. Cable, sure you can use an aftermarket Lokar unit, or hit the swap meets or salvage yards for a camaro that came with a carb from the factory, but I feel this is the most simple solution, and it worked for me....
Car: 87 camaro
Transmission: th350
Axle/Gears: auburn 4.10
1987 was last year camaro came with factory carb(as an option). That's were you'll have to look for a used setup. pre '87
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
something like this works very well and is simple using original throttle cable
88bullet (09-17-2019)
Car: 1991 RS Camaro w/ Factory T-Tops
Engine: Built 355 ci SBC w/ Carb
Transmission: Borg Warner T-5
Axle/Gears: 4.10 with Posi-Trac
I've got the same bracket on my '91 RS and it works great. For the money it's a great piece.
Car: 1992 Camaro RS
Engine: 350 Carb'd
I'm still having this issue... Tried many brackets setups with my tbi cable. Nothing worked
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
theshackle
09-17-2020 08:26 AM
92camaroJoe
08-13-2015 06:07 AM
