Edelbrock electric choke issue
Old 03-10-2013 | 09:47 PM
BroncoRN's Avatar
Car: 1986 Camaro
Engine: 350 - carb
Axle/Gears: Stock
This is my first carb'd vehicle. When I got it the choke was wired open - no wires to electric choke. I wired 12v to it from fuse box, grounded it, and adjusted thermostat to the middle. Set choke run at around 1200 rpm. Can't get choke to engage at start up. What am I doing wrong?
Old 03-10-2013 | 09:55 PM
tomlyons's Avatar
Car: 92 camaro rs
Engine: 3.1
Axle/Gears: rear disc non abs
Re: Edelbrock electric choke issue
set the choke almost closed when cold if the electric part works it should open as needed as you press the gas
Old 03-10-2013 | 10:00 PM
tomlyons's Avatar
Car: 92 camaro rs
Engine: 3.1
also it hase to wired to your acc key on and then adjust idle and idle mix screws and make sure you have the right cfm carb for your motor
Old 03-10-2013 | 10:22 PM
BroncoRN's Avatar
Car: 1986 Camaro
Engine: 350 - carb
Axle/Gears: Stock
What if electric part is broken? Need new thermostat?
If you turn key and its cold will it trip choke linkage to increase the idle instantly? What temp will cause choke to engage?
Old 03-10-2013 | 10:39 PM
tomlyons's Avatar
Car: 92 camaro rs
Engine: 3.1
the choke is egauged wene you press the gas should have about 1/8 to 3/8 gap at rear of flap on top your carb adj when cold in that position adj fast idle screw when fully open adj idle mix screws on front of carb strat with 1 and 1/2 turns out
theshackle
09-17-2020 09:26 AM
Ducati900ss
09-02-2015 10:05 AM
BlackphantomZ28
08-22-2015 02:00 PM
1985chevydude
08-20-2015 01:29 AM
86IROC112
08-17-2015 03:00 PM
Quick Reply: Edelbrock electric choke issue
