Tpi to Carb ignition problems
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
I am wondering if anyone can help I switched from Tpi to carb and after all my ignition seems to not work. I am thinking its the vats system or something like that. I am wondering if anyone else has had a problem like this if so how we fix it. Thanks guys
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Re: Tpi to Carb ignition problems
And if I did get the vacuum sec where do I get the wire from or do I get one put in and if I didnt get the vac dis what things do I do
you can't use your old distributor. the old wire that powered the remote coil is pink. The pink wire is the accessory hot wire to the coil. On a gm hei distributor this goes to the b+ of the distributor and the vacuum goes to a ported vacuum signal.
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
The white wire from the coil gets hooked up to the tach terminal on the Hei distributor.
theshackle
03-05-2017 06:37 PM
86IROC112
08-17-2015 02:00 PM
Sanjay
08-12-2015 03:41 PM
