Rochester quadrajet leaking from top fuel bowl? And needle
Old 06-16-2012 | 11:56 AM
Jfinnkma91's Avatar
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
When I start the engine up, it's starts overflowing thru the needles and goes on the top of the fuel bowl. I rebuilt this carb and it worked well before. I can't figure out what's wrong. Any ideals?
Old 06-16-2012 | 01:57 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: Rochester quadrajet leaking from top fuel bowl? And needle
Your float is either set wrong or stuck in the down position. Your car is probably running very rich too. You can pull a plug to find out.
I rebuilt my quadrajet and I have fuel coming up through the top and out of the exhaust. Same symptoms as you. Needless to say the carb is coming back off today.....
Old 06-16-2012 | 05:45 PM
Jfinnkma91's Avatar
Yea my floats looks bent at the hinge. Maybe that's causing it to stick open. I'm putting a new float in now hoping that fixes it
Old 06-17-2012 | 11:51 PM
Engine: L69
Transmission: A4
I took apart mine and everything seemed 'good.' I still took the whole thing apart and put everything back to initial settings. I hope this fixes my problem as well.
1992 Trans Am
05-10-2023 08:19 PM
colton_carlson
03-08-2019 01:21 PM
Infested
05-23-2018 12:56 AM
Andrew6.688
12-13-2015 11:59 AM
wayshegoes
08-17-2015 01:00 PM
