car sitting awhile. what do I do?
Car: 84 Z28 H.O.
Engine: HO 305
So I just bought an 86 Z28 and its been sitting 3 years. I was able to drive it home but not well. I changed the gas and the carb still has a pretty large flat spot and its rough to start. Aside from changing the necessary fluids in the motor what do I do to get the flat spot out? Thanks guys
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: car sitting awhile. what do I do?
Lots of things can cause a flat spot, but it's likely the accelerator pump. Look down the top of the carb on the primary side and you should get a nice strong stream of fuel. A full rebuild would be a good idea after a long sit anyway. Ignition components are likely corrroded also.
