Holley Throttle/Cruise Bracket
I've searched, but not found, a bracket for a Holley 4150/4160 that incorporates provisions for throttle return springs, throttle cable and cruise control cable. Is such a bracket available? If not, suggestions/pics would be appreciated.
JamesC
JamesC
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Holley Throttle/Cruise Bracket
Prior to me running a blower, I was able to just use my stock bracket...I did need to tweak it a bit, but it worked fine. I've asked this same question in the past and looked for the same myself, and I only found throttle/kickdown brackets...but I had to have a carb base mounted bracket with the blower...
EDIT: I seem to recall I was using a RPM airgap intake (which sits higher) - I think I ended up raising the bracket up off the intake using studs/nuts...don't know if that's any help....
Hotrodboba400
12-10-2019 07:07 PM
