intake manifold?
Car: 89 Camaro RS (lawn ornament)
Engine: 327 sbc
Transmission: TH350
Axle/Gears: Stock for now
intake manifold?
I have an 89 RS i'm gonna dump a 327 with built vortec heads, Lunati 60103 cam, Holley 600cfm vac secondary, and a TH350 behind it. I'm looking at intake manifolds. I found a pretty sweet deal on a Performer RPM intake manifold. Do you think this will suit my needs? Any other suggestions would be appreciated.
Re: intake manifold?
Edelbrock 7116 with a drop base should fit great under the hood.
You need a 1.5" drop base air cleaner. you can fit a 3" filter with no spacer or a 2" filter with the spacer.
Here is a good used one on ebay
http://www.ebay.com/sch/i.html?_trkp...&_sop=15&_sc=1
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I have an original Winters intake manifold from a 1966 Corvette 327.PM me if interested.
The Performer RPM line is marginal for hood clearance in a 3rd gen. You might want to look into a Performer EPS or the Weiand Street Warrior lines. They are both modern computer flow-modeled designs, (like the RPM), just that the EPS and SW are lower profile (allowing easier fitmet of a reasonable sized air cleaner) and designed for a sub-6000 RPM powerband.
Car: 91 camaro rs
Engine: 305tbi,lunati cam, vortec heads
summit racing also has some newer design manifolds. they have the summit racing stage 1 intake manifold 1700-6700 rpm range similiar design to the rpm but they retail at there store for 125 new they work great as i have one in my 91 and it clears the hood. they are available for the vortec heads as well thats what i have for the same price at 125
Engine: 327 sbc
Transmission: TH350
That winters one won't fit vortec heads. Some people say the build quality of the Summit manifolds are horrible. I will look into it though.
yeah he needs an '87-up one to fit directly without modifying the four center holes angle(two on each side)
anything between '87 and '95 anyways
and then '96 up were less bolt holes in the intake and heads, the new SFI years
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
