Q-Jet - Holley Question - Dual Snorkel
Car: 89 Formula
Axle/Gears: 9 Bolt 3.27
Building a L98 350 and going carb. Will the Holley 4165 spread bore fit using a dual snorkel air cleaner? I did measure and have around 9.5" on the bottom of air cleaner. I may go Q-jet but need to know which model to find and send to Cliff for his well known experience. I want to be able to use the cruise control also.
Motor will be done in 4 weeks so may as well get this item addressed before installation. I did read most of the carb FAQ's and excellent right up on HEI distributors and all brands of carbs.
Re: Q-Jet - Holley Question - Dual Snorkel
If you're talking about Holley list #s such as 6210, yes.
If you want a good Q-Jet for "performance", try to find 7029201 or -02. Avoid ALL 704xxxx (emissions crippled). If you want a feedback one, 1705x201 where x is 3 through 7.
Brinkkl2000
08-04-2018 09:29 AM
