float adjustment
Car: 1987 iroc
Engine: zz4 350
Axle/Gears: borg warner 9 bolt 3.70 gears
float adjustment
hi, i have a holley 650 double pumper i am trying to adjust the float level on. when i loosen the lock screw on the adjusting nut with the engine running i end up with fuel squirting out the adjusting nut area as i try to adjust the level. is this normal and if not whats wrong? thanks
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
It's normal. Try to only loosen it enough to be able to turn the nut, and only leave the screw loose for as short of a time as possible.
Car: 1987 iroc
Engine: zz4 350
Re: float adjustment
thanks, you are correct i was just backing out the screw too much without turning the adjusting nut.
LT1Formula
10-08-2015 08:34 PM
