Which Fuel line is supply and return?
Car: 1982 Z28 Camaro
Engine: 305 w/ 4bbl Edelbrock
Transmission: 5 Speed (?)
Axle/Gears: ?
82 camaro Z28 305 with 1406 Edelbrock...
Problem is... Replaced Mechanical Pump with old Electronic Diaphram Pump i had laying around that had 6-9 psi on it... Lasted for one week and burned up last night.... Purchased http://www.autozone.com/autozone/par...ier=191411_0_0_
After installing this pump i noticed the Fuel line i had previously ran to the old pump had a larger diameter line than the new one which now makes me think i was using the return line as the supply line...
Question is... on the passenger side wheel well are two fuel lines... One small and bigger... Which one is supply and which one is return?
Re: Which Fuel line is supply and return?
Supply fuel line is always larger, at least this is true of MPFI, but the same principal applies, so I am 99.99999999% sure it is true of carb as well, since more fuel goes in, then comes back out because the engine uses a good portion of what goes into it, fuel system only sends back out the excess.
Axle/Gears: ?
Fudge, That is what i thought as well... On the new pump has a smaller diameter outlet so the larger hose does not seat on it right... No matter how much i tighten hose clamp the hose still spins and small leak... The Outlet on the pump in not interchangable unfortunately. just looked on hose and it says 3/8" diameter Guess i need to go get 5/16" line then... Thanks for confirming!
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Correct.
3/8" is Feed (Large)
5/16" is Return (Small)
Car: 85 Z28
Engine: 327
What about on TPI cars that have been converted to carb. Then you have three lines. Which are which
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
no, its still 2, and the sizes are the same, they are just on different side of the engine bay, and have different connections. FWIW, most, if not all 3rd gens have 4 lines from the tank.
Only 2 of them carry fuel, one goes to a filter/vent on driverside wheel well, the other is for the EVAP can if memory serves.
-Carb'd cars:
*2 lines on passenger side:
Feed (3/8")
Return (5/16")
*1 line on driver side
Evap canister (5/16")
-FI Cars
*3 lines on drivers side
Feed (3/8")
Return (5/16")
Evap line (5/16")
Evap line runs to the charcoal canister
4 lines come out of the tank on all third gens, just one ends at the tank through a vent.
That should clarify.
Feed (3/8")
Return (5/16")
-FI Cars
Feed (3/8")
Return (5/16")
Evap line (5/16")
IROCullan (06-23-2020)
Car: 85 Z28
Engine: 327
That does clarify but with the evap and return which one is which. One is above the other. I don't have a canister so I can't see which one went to it
Car: 85 Z28
Engine: 327
So I was outside working on my car to hook up fuel lines, and noticed all three were diffent sizes. So big was supply. Hooked it up. I assumed the next size was return. So I hooked it up. Was that correct? And the smallest the I assumed was vapor and just ren a lenth of hose outside of car. So was it correct??
Car: 1991 Chevrolet Camaro RS
Engine: 305 TBI, planning on built 400
Axle/Gears: 2.73 stock axles
looks like it. Isnt evap to pressurize the tank? Maybe thats why my fuel system with my TBI isnt working so well?
No, evap isn't for pressurizing the tank, its for catching fuel vapor from the gas tank I believe, while the other non fuel carrying line is for preventing pressure build up in the gas tank.
I notice most other people have pointed out that there is a feed line, return line, and a vent line.... The 4th line is actually a brake line from the master cylinder I think... But there's definitely a 4th line going through the trans tunnel that's routed with the fuel lines and looks identical.
As someone who has replaced the fuel pump I know for a fact that there are 4 lines coming out of the tank.
Car: '04 Ram Hemi & '86 Camaro
Engine: 327 bored to 355
Axle/Gears: 323 posi
I'm really confused...How do you know how to tell them apart if they are all the same size... mine are all chopped off. I was going to do my fuel lines under the hood this weekend but don't how well that will go after readin this thread.
but they are NOT the same size, one is 3/8 od, one is 5/16 od and the other is 1/4. VERY easy to tell them apart......
1 Post
Car: 92 Camaro Z
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Sorry for bringing back an old thread but wanted to confirm that this is how i should route my new lines.
3/8 - supply
5/16 - return
1/4 - evap can
thanks
3/8 - supply
5/16 - return
1/4 - evap can
thanks
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Car: 1986 trans am
Transmission: 5 speed
i'm taking off my smog stuff. Can i just remove the evap/and return fuel lines?
Engine: Broke - 350
Some aftermarket electric fuel pumps that are for carb'ed motors can be run without a return but using a by-pass regulator and return line makes it easier on your pump. Same can be said about mechanical fuel pumps that are single feed in and single supply. Those will work without a by-pass regulator and return line as well.
Car: 1986 trans am
Kind of what i thought on the return line. What about the line coming out of the evap to the tank on the drivers side of the engine?
Engine: Broke - 350
That line in combination with the vent line in the rear keeps the tank from building too much pressure or from forming too much vacuum in the tank. The vent in the back only allows air in and the part to the canister draws the vapor/pressure off the tank and delivers it to the motor to burn it off. It would be wise not to fully cap it off, see what racers have to do to vent their fuel cells properly. This is what you are really trying to do anyway.
1 Post
Car: 1989 Camaro RS
Engine: 383
Transmission: TH400
Axle/Gears: 9 inch, 35 spline drag spool,4.56
Can someone chime in and tell me which line is which. Thanks.
Shadetree45 (06-13-2021)
theshackle
03-05-2017 06:37 PM
ambainb
04-25-2016 09:21 PM
AkDrifted
08-17-2015 07:45 PM
