injectors are not shooting gas out
Old 08-04-2011 | 07:20 AM
arturojralmanza's Avatar
i just got done rebuliding my engan cause it was really dirty. well now that i put it back together and back in the car, i cant get it to start. i took off the fuel lines and i am getting gas but the injectors are not shooting gas out.
Old 08-04-2011 | 06:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: injectors are not shooting gas out
Need to know year, engine, induction system, and any mods.
You've posted in the carb forum, which is the wrong place since you have fuel injectors and carbs do not have fuel injectors.
Old 08-05-2011 | 02:06 AM
its a 1990 rs 5.0. i dont know wat the induction system is or any mods.
it has these two injectors above the carb so i thought it was still a carb
Old 08-05-2011 | 06:38 PM
Car: 1992 RS
Engine: Carbed 350
No, it's not a carb - it's a TBI (Throttle Body Injection). Looks alot like a carb, but with two injectors that spray down into the intake.
ECM controls injector spray - I'm no expert on the injectors myself. But you'll get better response by reposting questions in the TBI section - make sure to state year of car and exactly what you disconnected/reconnected. I'd sure you just have a wire not connected back properly. They'll also be able to tell you how to test voltage on the injector wires, etc.
bryan623
03-22-2021 06:43 PM
jklein337
09-19-2018 06:23 PM
db057
09-04-2015 07:57 AM
Jae992
08-27-2015 09:07 AM
Quick Reply: injectors are not shooting gas out
