Fuel / Gas Filter
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Fuel / Gas Filter
Just curious with so many brands / types out on the market what are you guys with carbs running? Paper / bronze / other material?
I started researching this about a month ago as I have one of those Russell street filters 40 micron but read they are only good for "up to 300 horses". I am pushing over 300 and think this filter may be holding back my volume as my Z seems to hold back around 4-5k. Like it needs more fuel. My PSI gauge drops, but not sure if that is due to heat as it is liquid filled.
Just curious what filters you all are running with minumum pressure drop. And what you may recommend.
Thanks.
Thanks.
Re: Fuel / Gas Filter
Definitely a paper filter at that HP level. If you're running a QJet you'll want to switch to an external filter (remove the stock filter that's built into the front of the carb). On the cheap, a Fram G3 filter works fine on my mild supercharged 383 (~470HP at the flywheel). You can get as wild as you want from there, depending on your budget.
Car: 1982 Z-28
Engine: 383
Thank you Damon. I am running a Holley 650DP and have the Russell filter in between my Carter pump and Carb.
So the bronze filter in the Russell is restrictive? Are all bronze restrictive?
I was looking at the Jegs, Summit, Aeromotive ones and then saw the Holley / Trans Dapt ones that are a really cheap. Are those any good?
Pretty much anything that isn't paper is restrictive. Bronze, screen mesh-type, pretty much anything other than paper in my experience. It's hard to argue with the fow area of a multi-fold (pleated) paper element. Everything else just has the outter circumference to flow fuel through and filter it.
1992 Trans Am
05-10-2023 07:19 PM
92camaroJoe
08-13-2015 06:07 AM
