HVH super sucker carb spacer
1 Post
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: HVH super sucker carb spacer
I think the general consensus from the prior thread was that they are a good tuning aid if you're looking for something different to try. While there's a potential power gain - it probably won't be very much.. and in the scheme of things, $100 for 5 horsepower just isn't worth it. The results vary for everyone I've talked to that has tried using the spacers, so it really just depends.. is it worth $100 to you to find out? Personally, I can find plenty of other ways to spend $100 that are guaranteed to be effective.
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
You could buy a cheap, 4-hole phenolic spacer and make your own "super sucker" with a die grinder and some patience. I think mine cost a whopping $20. It made a huge difference in low speed driveability (increased signal to the carb maybe). It was worth it. However, I saw no gains at the track.
