Upped the jet sizes, runs WAY better, but almost dies when I stop.
Old 05-18-2011 | 06:44 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 383
Transmission: TH350
Axle/Gears: 4.11
So, I popped in 68\72 jets in 670 my street avenger today (up from 65\68). The off idle bog is GONE. Runs beautifully. However, sitting in the car at idle seems to stink like a bit of exhaust. Also, if I stop sharply or just rev it and then hold the clutch in, it almost dies now when the rpms drop.
Are these common problems of running rich? If so, why would the car run perfectly once it got too rich?
Old 05-18-2011 | 08:19 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Re: Upped the jet sizes, runs WAY better, but almost dies when I stop.
Jetting has nothing to do with the idle mixture. You must have accidentally turned the mixture or the idle adjustment screw. Sounds like its the idle that is messed up.
Did you try increasing the idle or leaning out the idle mixture? I would try the mixture screws first.
Old 05-19-2011 | 07:31 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
like mentioned, off idle bog is not solved by increasing the jets.
May be accelerator pump adjustment, may be transition slots, may be idle mixture screws.
If you are talking about off idle to WOT, then it could also be from the PV
What do you mean like a stink of exhaust? You could have a leak somewhere. OR do you mean that the exhaust smells like raw fuel?
jklein337
09-19-2018 07:23 PM
pimp2303
07-27-2017 03:03 PM
apo_bailon15
03-28-2016 06:20 AM
eightsixseven
08-14-2015 04:09 PM
knight72
08-10-2015 10:32 PM
