2 barrel conversion
Old 05-17-2011 | 09:14 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
2 barrel conversion
i was wondering if anyone has replaced there 4bbl with a 2bbl if you have could you explain. im thinking of putting a carter 2bbl on mine.
Old 05-17-2011 | 11:58 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Any particular reason you are considering doing this?
Old 05-18-2011 | 12:01 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 2 barrel conversion
Ill guess
Lead foot
[Can't stay out of all 4 if they are there, they can be locked out on a qjet if temptation is to much.]
Old 05-18-2011 | 12:55 AM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
the car is going to be my dd and a 305 isnt exactly fuel effiecient so if a 2 bbl uses less gas that would be good.
Old 05-18-2011 | 10:15 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The driver has more to do with the fuel consumption rate than the carb.
Old 05-18-2011 | 03:50 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
i want it to get more then 17 mpg
Old 05-18-2011 | 04:11 PM
80smetalfan's Avatar
Car: 1989 IROC
Engine: LB9
Axle/Gears: 3.42 Posi
17 MPG city....you can do it if you don't mind being a slow and patient driver.
17 MPG highway...that's easy with a 305, especially if you have an overdrive transmission. If you've got a healthy 305 and 700-R4, you can hit low/mid 20s without too much difficulty.
You probably need to start thinking about a good tune up first, and making sure all of the basics are good. I can't really imagine how a 2 barrel swap would be worth the effort unless you've got a nice fresh 2 barrel carb sitting around and your 4 barrel unit is worn out.
Old 05-18-2011 | 04:22 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If its a qjet, you can easily lock out the back two.
Old 05-18-2011 | 04:23 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
On my 1987 LT with the 4bbl. 305, i've gotten anywhere from 9 mpg's (Lead Foot) to up to 18+ mpg (normal, everyday driving in rare non stop n go driving). A well tuned vehicle with clean filters and a good tune up will yield those numbers. So I am in agreement with 80smetalfan
Is your Camaro the only vehicle you have?
Old 05-18-2011 | 04:45 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
it is going to be my car but at my house there are 2 other cars that get 25 where i live its all stop and go
Old 05-18-2011 | 06:10 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Most people don't believe it but my old daily driver '85 Trans Am with an LG4/auto would get 25 MPG city and 30 highway.
I know it's hard to believe but there are other people (at least one on here) that can confirm it. The car was just a MPG freak.
Old 05-19-2011 | 08:47 AM
Car: 1989 IROC
Engine: LB9
I believe the 30 MPG highway. My old 91 with a L03 TBI/700R4 and 2.73s could do 30 MPG highway pretty easily. I even did one 1500 mile trip over a weekend where it was nearly all long highway drives and hit 33 MPG at one point. Lots of people on the TBI boards have gotten 25-30 MPG with L03 cars.
It's all in the tune. Even on these Quadrajet cars, you can get away with pretty good mileage if you spend some time getting a good fuel tune and getting your ignition timing dialed in. I have no chance of getting anywhere close to 25 city with my 455 car, but I can do better than 20 on open highway driving without too much trouble. I know a guy with a built 11-1 Caddy 500ci in a 80s Regal and a 200-R4 that gets 21-22 MPG on the highway with a Quadrajet.
Old 05-19-2011 | 10:46 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Driving to and from San Diego I average between 26-28 mpg. The quadrajet is a good carb if properly tuned. Btw, anyone tried that Holly fuel injection carb replacement that has the injectors that look like four eggs?
Old 05-19-2011 | 11:27 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
All depends on how fast you drive city, if your doing 50 plus in the city with few stops.......
How I get high city in mine, all very long country blocks, that let you do near 50 or more without worry.
Old 05-19-2011 | 03:58 PM
five7kid's Avatar
Engine: LS1/LQ4
I suspected as much, so that's why I asked.
You won't do better than the stock computer q-jet for fuel economy. The 2 bbl is older, bigger, has less refined circuits, and will use more gas than the q-jet.
To say nothing of the gas you can buy with what converting to a 2 bbl will cost you.
Old 06-02-2011 | 11:25 PM
thetrucker21's Avatar
Car: 2000 Camaro SS
the 2 barrel carb wont change much but the fact that your secondaries wont open up past 4 grand ish, obviously cause they arent there. save yourself the work just drive conservative :] thats how i get my MPG with my Camaro. Plus on a stock q-jet the primaries are small they provide quick take-offs and use less gas. My dad took off his 750cc holly carb and but back on his stock q-jet to save gas and now he gets 24 MPG around NYC
Linson
09-25-2021 08:55 PM
smnichol86
Brakes
26
03-26-2017 11:55 PM
oil pan 4
Fabrication
10-06-2015 12:56 PM
loud91rs
10-05-2015 11:05 PM
mfp189
09-27-2015 10:25 AM
Quick Reply: 2 barrel conversion
