Throttle Position Sensor
I have an 83 with the 305 feedback q-jet. Recently I rebuilt the carburetor because she was running rich (o2 code/terrible gas mileage). Did the dip and all. Came out looking great. I was in a rush putting it back together and I snapped the TPS plunger, so I bought one and had to waited to throw it in. Idles fine, accelerates great and overall sounds like it is in running correct. But,now I'm getting the TPS out of range/low voltage codes. It only comes on when I accelerate slowly and use low throttle ranges.
It is an Autozone part(TPS100) so it is very likely it could be bad. Anybody experienced in the CCC carb world like to enlighten me on my situation? Resistance the sensor should be at? I get bummed every time that check engine light pops on.
Thanks!
Thanks!
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: Throttle Position Sensor
Welcome -- there are several recent posts to search out in the last 2 month in the carb section that might answer your question
Assembling the airhorn assy. onto a CC-Qjet is tricky. It's easy to wedge the TPS dowel/plunger or get the TPS adjustment "hook" pushing on parts of the TPS body it shouldn't. Takes a little practice. Some stiff grease on the dowel/plunger to hold it up in it's hole in the airhorn casting before you flip it right-side-up to put it on the carb can be a big help.
haha yeah You called it. I didn't know those guys needed adjusted. It is now got a little hicup at a certain throttle degree. I need to go through and double check all of the adjustments.
TheTraut88
09-07-2015 05:22 PM
someone972
08-30-2015 12:52 AM
